Noozle clogging. New method to clean. Variation of Atomic/cold pull.
Note: Here is a picture of the pull ends I got with my method AFTER I DID NORMAL ATOMIC/COLD PULL FIRST and had a clean filament and thought the problem was fixed but was not satisfied.
Well, most of you probable know the “Atomic” (cold pull variant) way to clean clogged heads. It has saved me many times but not allways. And I think I found a way to improve the result.
Some time ago I had a clogged head (On Ultimaker 2) after printing with some exotic materials. Followed the atomic procedure until the filament was coming out clean, started to print and the head clogged again. Repeated the procedure and got some dirt out until filement clean and started print again. But was not satisfied with the flow, seemed uneven but still feeding. Had studied the atomic method and had some ideas which might improve it so I decided to try some ideas. Will detail here step by step what I did for those who are not familiar with this method. Basically the atomic method with some deviations which seems to improve the result dramatically. This is for Ultimaker 2 with bowden tube but you should be able to adapt it to your printer.
1: Remove bowden tube from head assembly.
2: Cut some lenght of filament from a spool (30-40cm). FOR BEST RESULT USE NYLON FILAMENT!!! If you don’t have that available you have to experiment with the temperature settings and in my experience I had not as good results. And even Nylon temperatures will vary between manufacturers *note 1
3: Heat Noozle to 260 deg Celsius (MAX temp on Ultimaker 2 or max temp your filament can stand without instant burning).
4: Feed Nylon filament into the head and push down until (some) nylon starts to come out of the noozle, quickly lower the temperature to 90 deg Celsius. KEEP PUSHING the filament in because at 260 deg Celsius you are practically cooking the nylon and you don’t keep feeding you will burn it and make the clogging worse. Also don’t make the nylon make a blob on the noozle, preferable is a thin solid thread.
At about 182 deg Celsius it will get harder to push the filament in and you can then let up on the pressure on it until it stops flowing at about 179-180 degree Celsius.
5: Let the print head reach 90 degress Celsius and let it idle for 5 minutes or so. (Or more, longer times don’t hurt. Grab some coffe or read your mail.)
6: Cut excess filament thread feed from noozle, about 1-2 mm from noozle.
7: Prepare to increase the noozle temp, pull tight on the filament and slowly increase the temp. At about 140 deg celsius the filament should loose its grip on the noozle and get loose. On the Ultimaker 2 I actually pull so that the spring holding the PFTE insulator and Noozle/heater assembly in place compresses a little and the assembly lifts from it’s seat and snaps into place when the filament looses hold.
8: Examine filement end. Cut the dirty part off. (2-3 cm)
Is some dirt on/in the filament? Then repeat the process from step 3.
Is the excess filement that had exited the noozle on the filament end? If not repeat from step 3.
Look through the noozle from the top. Can you see through and the noozle opening round? If not repeat from step 3.
Usually after 2 passes from step 3 everything is nice and clean and I can start printing again. If the flow is seriously hindered on the first pass or completely blocked you may have to do it 3-4 times to make sure.
*note: I have found out that using Nylon gives best results. The temp “window” from solid to completely fluid seemst to be wery small. Mostly rigid at 178 degrees C and like water at 185 degree C and floats into every available space trapping particles. Very strong immediatly after cooling and will not break about 1 cm into the noozle when you pull as other materials often seem to do, leaving worse clogging behind
And the nylon glides smootlly and doesnt stick when solid.
Here is a picture of the pull ends I got with my method AFTER I DID NORMAL ATOMIC PULL FIRST and had a clean filament and thought the problem was fixed but was not satisfied. Suspect this is accumalated dirt because it is much easier to clean the head after this cleaning and usually it looks like filament no 2 on the first try.
Hope somebody finds this usefull
