Not sure where to post, so I have dual posted here and the google group.
Good Day all !!!
I am nearing the end of a full rebuild of my machine (Shapeoko II). This means a enclosure for the electronics, full rewiring throughout the machine (it was always a slop with prayers that it would hold through the job), and the addition of homing switches. In the process, I figured I would also get myself caught up with GRBL 1.1 (on a GRBL Shield). Chilipeppr has been my goto interface of choice ever since it was made public.
Once I started powering everything up, I have been troubleshooting all the little things that come up. I have resolved most of them, but I am still not in the position to start running jobs. I have a couple of things which are causing some real stress as I can not find any real answers. Read that to mean, yes, I have been searching and working like crazy to fix as much by myself as possible. But I have hit a wall here and it seems that here is where I need to start asking for some guidance.
I have seen the posts about using the Jpadie workspace. So, I have started to try to use that. This made it possible to see some feedback as to location n such. The problem, it seems, starts when I home. I have my X and Y inverted for the homing cycle so that I land at my lower left hand corner. Homing seems to work well. But this is where the oddness starts. I will get an incorrect read in my movement. I am set to work in mm. If I ask the machine to move 10mm, it seems to move 10mm (The spindle is off, but it looks like a visual 10mm). The readout however will display that I have moved a fraction of a mm. I saw a post where someone had a similar issue. John asked the person to click the in/mm button. When I try this, it is a similar situation in movement. It seems to be a proper movement, but incorrect reading. Initially I thought I might have found the issue as I had $10 set to 3 (my GRBL .9 setting). I set this to 1, but it is still not working.
Another symptom which might be something new, but I am unfamiliar with (this build has taken far too long (over a year) do to work, family, and life in general). Where I was quite up to speed on everything before I started, I have not been in the loop for a while, so all advancements have passed me by. I am looking for documentation, videos, anything, but I am not seeing this…
After homing, I see a string that is unfamiliar. The string contains a feed rate. I am thinking that this is the new jogging mode in action, but the speed is silly slow. I figured it would take the seek feed rate but this doesn’t seem to be the case. Unfortunately I am at work so I can’t give an example of the string it’s placing. Prior to homing the machine moves about similar to what I was used to prior to the upgrade.
Having read that there seems to be some things not quite right with the combo of Chilipeppr and GRBL 1.1 in general, I (reluctantly) have started trying a couple of other softwares. Interestingly I have the same problems there as well, which tells me that either 1. I have something configured incorrectly (which is quite probable). or 2. There really is some oddness in 1.1 which needs to be addressed and I need to be patient, or go back to .9 (which I am having some issues with as well).
So, I will leave this here. I am just not sure which direction I need to head. Thanks for any help you can provide. I can get any screen type info you need as soon as I get home from work in a couple of hours.
Mike
