not your average everyday print jobs. Originally shared by Michael Interbartolo 3D Printing........
3D Printing… IN SPACE
The 3-D Printing In Zero-G Technology Demonstration (3-D Printing In Zero-G) is the first 3-D printer for operation in microgravity and may change the way NASA does business aboard the International Space Station. It is scheduled to launch to the station aboard the SpaceX-4 resupply mission, and researchers hope to show a 3-D printer can work normally in space and produce parts equitable to those printed on the ground.
The 3-D printer works by extruding heated plastic, which then builds layer upon layer to create three-dimensional objects. Testing this on the station is the first step toward creating a working “machine shop” in space. This capability may decrease cost and risk on the station, will be critical when space explorers venture far from Earth and will create an on-demand supply chain for needed tools and parts.
Lessons learned from this 3-D demonstration will be used for the next generation printer known as the Additive Manufacturing Facility (AMF). The AMF will be a commercial printer that will enable not only NASA to print needed parts, but will also set a precedent as the first facility ever to provide anyone on Earth – including academia and industry from around the world – the opportunity to manufacture parts in space.
#scienceeveryday
http://www.nasa.gov/mission_pages/station/research/news/3D_in_space#.VAYSl47HXss.google_plusone_share
So in zero G the issue of support material is kind of a moot point huh?
Some people have all the luck.
@Anthony_Truss I doubt it. It would simply be renamed an “anchor” and serve the point of not letting that section float away from where it is supposed to be.
They should also consider solar smelters and CNC milling.
If bonded to the “raft” or “bed” do you still see a need other than isolated individual parts not attached to the main model.
Either way it’s gotta be easier than at earth gravity.
@Anthony_Truss You have to press the fresh material against something or nozzle based 3D printing will not work. If you print a person, for example, the person’s arms may hang down at the person’s sides and would need “anchor material” for that purpose. I suppose if you have an ultracomplicated printer that can rotate the nozzle along the X and Y axis, you might not need “anchor material”, but it might not be necessary for them to have such a complicated printer unless they plan on printing on pre-existing objects like perhaps two broken parts or two misc pieces of junk.
