#polycarbonate #layer #adhesion
Now we need to fix layer adhesion but my hotend is not running hot enough apparently to get good adhesive
but got to love the strengt of poly… this Gopro quickrelease is ok in ABS but eventually breaks after multiple use. this does not even show Whitening when bending
How hot are you printing?
260 degree hotend and 100 bed. If i go higher than 270 degree I sometime have emergency shutdown because of overshoot
I printed a PC gear yesterday, 300/120. for bed used kapton and superglue on it. Printed with raft, infill - 1, concentric. I guess 270 should be suffisient, but you have to print very slowly
ah, I guess I answered your comment in my post
Yepp afraid of this. My hot end is not made for those temps… I will have to upgrade some time in the future
But the paper and glue stick worked very good for warping
you need a 2 dollar resistor as a heating element, what else do you need to upgrade?
The sensor to I think
I think, a thermistor that you have there could measure temps around 300…?
