Nozzles just kinda accumulate on you…
Will your next organizer print have the nozzle sizes in text adjacent to each opening?
Nah, top to bottom is .25, .3, .35, .4, .6, .8
I know what size they are and they have the dots. Good enough for me.
E3D heaterblocks too…
@Taylor_Landry
Older, worn, smaller nozzles become larger nozzles. (I have a few appropriate drill bits.)
Question about nozzles. I just had a scare when I suspected that my nozzle clogged although it did not. (Sign in - Google Accounts) At the time I tried to probe the passage with a ø0.3 wire, knowing it was a 0.4mm nozzle. But however I tried, the maximum distance I could go was like 1mm or less. (The hot end was heated.) Should I expect the wire to pass?
Yes, it should pass through.
