I have been trying to add a relay(5v and 12v) to my Nvum controller to run my dust collector and have had no luck getting it to work. Can anyone help??
Iot Relay - Enclosed High-Power Power Relay for Arduino, Raspberry Pi, PIC or WiFi, Relay Shield https://www.amazon.com/dp/B00WV7GMA2/ref=cm_sw_r_cp_apa_i_gq4oEbXEJXQTX
Welcome, Dan.
I am not familiar with a Nvum controller. Can you point us somewhere that has more info. on the controller?
What have you tried so far?
I’m sure we can help … with the right output from the controller the controllable power strip @HalfNormal suggests could work or you could build your own equivalent.
I have been working on it again today. I am new to 5v relays. Is it normal to need a 5v signal to trigger it?
Is this what you have?
That is the one I have
Thanks Ned. I will give that a try. I will let you know if it works
Dan
can you provide a wiring diagram/schematic of how you have it wired?
