Oak cut TT bat and Celtic knots. The small balsa wood logo engraving was the very first thing I made.
How did you set the machine parameters to cut and engrave? How thick was the Balsa Wood ?
Hi Antonio, I’m sorry I did not record the details of those jobs, engraving djrm on the thin balsa wood (<2mm) needed quite fast travel at very low power, more would burn right through. The bat and handle are approx 4mm oak faced plywood, they were cut slowly at nearly full power, I gave them two passes. The Celtic knots were somewhere in between, they are vector drawings and so are cur not engraved, if I remember correctly. hth David.
Thank you
