Ok guys,
So I have a brain storming item for you.
I am looking at using Arduinos in permanent installation.
Think of it as a light controller placed in a PLC.
Have you used anything in a way that was mounted on DIN rail and with permanent connections?
Thoughts:
This would need screw terminals for wiring.
DIN rail mount.
Possibly static protection inn the case.
Power will be supplied from main PLC at 220, I’ll step that down with a step transformer to -5VDC This will also power the lights as well as the board.
Capabilities:
I can make just about anything I need… and have fairly easy access to the rest…
I already have a setup in mind and am working on it - but I think this might be of interest for the community, so it would be great to hear other thoughts on how to do it.
