Ok, i’m trying to clean up a little of the mess i´ve made thru the past months. I know a lot of people are confused about what parts are the latest on so on.
So to begin with i will take take an assembly at a time and it´s related parts and put them all in what i would like to think an orderly fashion over at GrabCad.
I´ve started with the differential. Folders will be sorted according to “sub assemblies” such as the diff. Each of those folders will contain folders for STP files aswell as STL files. Once files are updated GrabCad will automatically create a new version for that particular file so you will always have the latest version of that particular file. However, if you need to you can access older version from a menu available once the file is opened.
The folder with the STEP files will also contain the assemblies.
Documentation will also be available in it´s own folder.
From now on during development i will ONLY post files on GrabCad.
As usual i would really like to hear you comments and thoughts on this.
(The link will take you to the differential folder)
https://grabcad.com/library/openrc-1-10-3d-printable-rc-truggy/files/Differential/
