Ok just came up with a quick way to check the high voltage output on the power supply, but a spark plug tester from the hardware store and hook the cathode and anode leads up to it, it has a neon light in the middle of it, you can also set your voltage with it hooked up.
Both…it’s reading the 15k output from the transformer.
