OK so i decided to try laser web since i recently switched to smoothie
OK so i decided to try laser web since i recently switched to smoothie based platform. and i am at a total loss on how to get this thing to work for k40
  1. prints images mirrored since K40 homes awkwardly and there no option to change this in laserweb
  2. Gcode uses S0-255 in command but smoothie needs S.01-S1 to change power. so i dont know if im missing something there
am i missing something or is this all as intended
@Derek_Schuetz ​ go to settings under gcode and put the on off commands plus the range there
Can you show me an example it says to type 0-255
Sure must be 0-1 for. Smoothie
@Derek_Schuetz ​ this are my settings http://imgur.com/loGr79k
Oh wow literally just a 1
What about it mirroring my images
For the invertion you need to change the config file. Y axis must home to limit max so it Park on the top left. The best is to send you the config file for your reference but I don’t have it at this moment.
In the meantime you need you Y endstops as Max and home to Max Y
ok i just ddi that so i have it all configured as such but now its just slaming into the side because it things positive is negative direction
Don’t move the X. You just need to flip the Y. Either physically or with a ! Next to the dir pin
Can you send me your file.
ayahni@gmail.com
just sent
What board do you have?
AZTEEG X5 MINI V2
motion and laser firing is all good its jut the gcode that laserweb spits out
You beta endstop seems fine. What’s seems strange is all the invertion you have in the Dir and enable pin for the steppers
Laserweb just send the code, so pressing up should move the gantry away from you
you have to invert the stepper direction if you change it to home to max otherwise it just goes the wrong way.
