OK so this morning i started my cleaning and mirror alignment.
Did you adjust the laser diameter to over 0.1? That’s a key point on this
I set it to 0.1 I am going to reload image and set it to 0.4 and work my way down. I am engraving now with 0.1 300dpi and image size of 100x75 MM at 150 mm/sec it is almost done.
OK Ariel now I am making progress. I d/l and installed the newest LW. I imported the same image and set diameter to 0.4 and it worked. set diameter to 0.3 and it worked. Set to 0.2 it generated code but screen is white after that.
What specs is you computer. I suspect a video card issue here. Screen turning white is a WebGL issue
Ok I am using a laptop cause I can take it to my laser. I will load LW on my gaming computer and try it there. I know there will be no video issues with it. Thank you for all your help.
Ariel I believe your right it was my older weaker laptop. I have a second laptop that is more gaming and It works good on it. Thanks again for the help.
My pleasure. Hope you have a better time using LW and your machine
This could also be caused by low memory, as the browser (app) needs a lot of memory while generating the gcode for large high density rasters.
