Okay I am a little bit confused with delta calibration?
Okay I am a little bit confused with delta calibration? So I followed the guide on this page.
On 3D Delta Printers....
Now run script A in RepetierHost / click button A in Pronterface. The >>carriage should move up to home, then down to a point in front of tower A. >>The proper height should be just above the print surface, with clearance >>space for a single sheet of paper to slide between. Adjust the end-stop >>screw only for tower A if necessary, then repeat the test by running the >>script or clicking the button. Repeat until the paper slides between the print >>surface with only slight drag.
With tower A adjusted, move on to tower B, and then to tower C. When >>tower C is adjusted, you should be able to go back and successfully repeat >>the test on tower A without having to readjust.
I tried this with redeem but I have some strange behavior. I do not adjust the endstop screw I thought instead of that I use the M206 command to modifie the x, y, and z offset.
But after I calibrate tower A then tower B and then tower C… I switch back to tower A and then I need a readjust … so its a never ending story I always need to readjust something.
Is M206 not for that usage?
Or does someone know whats going wrong here?
thanks
