Okay, I got another Kisslicer question. So I like my first layer to be extruded at a higher temp than the remaining layers. My problem is that when Kisslicer lowers the temperature after the first layer, it uses M109 to set the extruder temp and wait. I’d reather it use M104 to just set the extruder temp and keep extruding. Right now, the nozlle drips as it’s waiting for the extruder too cool to the new temp. Where can I change this?
In the Ptr Gcode section, go to select Extruder Tab.
Change the M109 to M104
In the Prefix tab, put an ‘M109 S’ to make sure it heats your extruder up before it starts the print.
Ah, that just makes way too much sense. Thanks!
