Okay, so I’ve got a bit of a conundrum. I’m trying to generate the gcode for laser filling paths on the following images:
https://drive.google.com/file/d/1bVqg-qZJyaRQhsdGdd5EXHFBkNsjwA6j/view?usp=sharing
(Adobe Illustrator Version)
https://drive.google.com/file/d/1ksvhpHgBWrps-KKLo3JGHWcoYuXUbD79/view?usp=sharing
(Inkscape Version)
In the file, I’ve grouped together sections (Main Body, Stitch Holes, Quote, Earth, Sketch).
Earth & Quote will generate the laser filled path. However Sketch stalls out. Sketch stalls at 49.5%.
I’m using settings 0.1 line distance, 0 line angle, 25% power, 0 margin, 1 pass, 25mm/s Cut Rate.
What I’m wondering is, is there some problem with the saving of my files that is causing this stall? Or is the path too complex? Or am I being impatient & should wait longer than 5 minutes for it to generate?
Thanks all.
