One last question (hopefully). When using the Alignment tool for the eustathios V2, does the alignment tool bolt on to the frame or? Does anyone have picture’s of their proper use?
They don’t need to be bolted on. Here is how I used mine. Please note you may still have to tweak it to really dial it in once you have used them. The precision of the printed alignment tools is only as good as the accuracy of the printed guides and the assembly. This should just give you a good starting point: https://plus.google.com/+EricLiensMind/posts/Bso1ocs77iv
Thanks, yeah I looked at those pictures. But was not sure if you bolted down or not. Thanks
