I am in the last stages of setting up my printer. I have to run PID tuning and then I am ready to print. When I started the auto tune on the hot end, I got an emergency halt and a message to check my thermistor as it was below min temp. I started checking the thermistor pins and changing which ones to use in the config file. As it turns our, both of my thermistors read but only when hooked to pin .24 Pins .23 .25 and .26 show zero no matter which thermistor is hooked to it. Do I have a bad board? Any help would be appreciated. This has been a long and steep learning curve. I finally got Zprobe grid running and now my heaters wont work.
