If you can print the 3mm filament with you current nozzle, you may experience more extrusion resistance. You will of course need to set the filament diameter in the slicer.
Did a little more research… I’d have to swap out the throat and the nozzle. And the “tension arm” on the feed assembly is only drilled out to accept 1.75mm, so that would have to be changed as well. Might be smarter to just buy a 3mm extruder for $40, use it as needed, but get parts to make it a second 1.75mm for dual extruding on a regular basis. Need to think it through.
