Optical Sensor Module
As part of my VG-L7X Engraver project I have been thinking about optical measurements.
I found an optical sensor and a module for that sensor. As usual there either are no schematics or confusing ones available.
It’s a pretty simple PCB so I created a schematic: https://www.digikey.com/schemeit/project/opt101-module-5f5bfbe080b24f45a4dbe1bf695e7914
You can also see what I am tinkering with here: Don's Laser Cutter Things: Design Phase: Diode Engraver Relative Power and Focus Measurement
As far as I can see from the datasheet, this sensor can only handle power in the range of mW.
Yes, part of the challenge is to reduce the power to the surface. These units have a low power mode that I will try plus a diffuser of some sort.
It’s pretty sensitive at about 0.5v uW. Keep in mind the possibility of it going into saturation affecting the recovery time…
With that kind of laser, how can you control the current? I thought it had a ‘module’ with a pwm input.?
How are you planning on reducing the optical power?
Sorry to open something,… just wondering how it went?
:smiley_cat:
The project is on the back burner due to other stuff.
I plan to use some form of attenuation like used in cameras or alternately materials with some absorption at that wavelength.
I plan to use some form of attenuation like used in cameras or alternately materials with high absorption at that wavelength.
