ordering glass beds from the place in the BOM. anyone want to do a groupbuy? i’ll be getting the quotes later today and will post them.
What are peoples thoughts about wanting the system to integrate a probe and PEI covered spring steel flex plate?
BTW Wes, thanks for coordinating a potential group buy.
Np! And are you thinking like the mk3? Friend has the mk3 and the bed is pretty nice
I would love to have a PEI covered spring steel flex plate. On both my Herculien and coreXY.
Anyone know a good source for waterjet cutting and plating springsteel? And what grade spring steel is good for our temp ranges?
Thanks,
I would definitely be interested!
looks like maybe people are using 1095 Spring Steel?
Then again Buildtak makes a 12x12 version, perhaps going with a standard one that is easily sourced would be better?
@Eclsnowman Going with a 12x12" might be a way to make it “universal” and instead design magnetic mounting options that are compatible with each printer. For oddly shaped beds like that of my coreXY (11.5"x19.75") or larger printers like the Herculien I think it would be good to find an OEM willing to provide custom sized sheets though
I noticed the prusa mk3 uses a couple alignment pins on their spring steel sheets to keep it in place. Is that something to consider as well?
@Ryan_Fiske Yes, I like that design. Magnets are good at pulling in line with the magnetic poles, bad bad in shear across the poles. So pins take all the shear load to avoid shifts, and the magnets just hold it down.
Here is the below quotes for the glass. This does NOT include shipping/freight.
Clear Borosilicate Glass, Edges Cut & Swiped
345mm (13.58”) Wide X 360mm (14.17”) Long
3.3mm thickness
Qty. 1 $50.00 (minimum)
Qty. 2-5 $27.61/each
Qty. 10 $25.88/each
5mm thickness
Qty. 2-5 $36.54/each
Qty. 10 $35.08/each
Also, pins would be nice for alignment, but the magneys should be strong enough by themselves
i am interested in the group buy too! i think its kinda curious how this fall during girl scout cookie season too…the glass migth be cheaper by the ounce anyhow, i have yet to see an i3Mk3 bed in the wild- I would be worried about the residual stresses in the spring steel. it is GOING to have some warp in it naturally on account that its a coil product. as far a grade goes, could be 4130 too.
my plan was to get some PEI sheet from CS Hyde and then go from there… they do have up to 10-20-30-40 mil sheets. the 30 & 40 roughly translates to 26 ga and 20 gauge sheet metal. you could use magnets to trap it to a ferrous element under the sheet and locating pins to fix it in X & y. What I am hoping will work is to use water based glue stick or aquanet to stick it to to the glass. That way if i needed to get the film off, soak it off and flex it a bit to release the print then reattach. Prblem is, PETG sticks too good to PEI. I am ok with just Aquanet on glass.
if you go glass, the best bed is elmers E38XX glue, undiluted. spread it out on the bed, wet your hands and smooth the top out. it will get you a mirror finish and once the print cools it slides right of. as far as the spring steel goes, it does deform, but only naturally back to the origianal position, like muscle wire or sorbothane.
@wes_jackson I am also interested in the group purchase . I currently am using a piece of glass form an old refrigerator, and it is under sized.
so thats 3 so far, how long should we wait?
