So I usually set up lights so that 2 strips or strings are coming from one controller, located centrally to the strips.
When I create an array of the 2 strips the pixel order gets all outta whack yo, sorta like this brilliant paint diagram shows.
What I want is the first pixel to be the 12th, with the first strip’s pixel’s ordered back to front, starting at the end of the strip and finishing at the arduino, where the first pixel of the next strip joins the array.
I’m sure some here have had much harder pixel ordering problems than this
void setup() {
delay(3000); // 3 second delay for recovery
// tell FastLED there’s 20 NEOPIXEL leds on pin 10, starting at index 0 in the led array
FastLED.addLeds<NEOPIXEL, 10>(leds, 0, NUM_LEDS_PER_STRIP);
// tell FastLED there’s 20 NEOPIXEL leds on pin 11, starting at index 20 in the led array
FastLED.addLeds<NEOPIXEL, 11>(leds, NUM_LEDS_PER_STRIP, NUM_LEDS_PER_STRIP);
uint8_t LeftSide[NUM_LEDS_PER_STRIP +1]; //always one more !
for(int x=12; x>0; x=x-1) { LeftSide[x]=x; } // this fills the array with numbers 12 down to 1
