Originally shared by Ben Delarre
This weekends CNC + LED project. Its Chinese New Year so we cut this fairly traditional pattern into some 12mm plywood. I then thinned it down from the back side till it was thin enough to let the light glow nicely. With a second layer of 12mm plywood to act as a spacer. I then added 140 ws2812 leds to a thinner sheet which I will screw into the back.
Came out lovely, still have a lot of sanding and finishing to do but the effect is awesome.
