The Hydra with its shroudless direct bolt on fans. The fans just hit the base of the rod clamps on the x/y ends changing print area to 12 x 11 ⅝. I’m not happy. The STL will be fixed by shaving off 2mm and I’ll file these down so that I don’t have to reprint and disassemble.
Hey @D_Rob , how’s this coming along by the way? Very interested in knowing if you’re running into the same problem that @Tim_Rastall was having with non-straight rods and the rotation causing problems.
Haven’t had time to work on it. I’ve moved and am starting college Monday. Hopefully soon though. I see no visible bend while rotating manually though.
