Anyone use the new ‘DesignSpark Mechanical’ CAD program and print out a .stl model to see if it’s measurements translate to the realworld correctly? Here is a model I made to test when my bot is up and running again. https://www.youmagine.com/designs/40mmcube_ds2
DesignSpark is based on a real CAD program (SpaceClaim), and in CAD you always work with real world units. The only translation error that could happen is if you didn’t work in millimeters. I’m guessing working in inches may be an issue, but I have not tried it - nor do I plan to, since I do not use Windows at home.
1 question: I did a 10mm cube, design and found the printed object is nearly 10.25(I am using analog caliper) and my nozzle is 0.4 mm . Is this a accepted behavior? Do we need to take the nozzle dia into account when designing ?
