Originally shared by Drew Fustini (pdp7)
<b>Any kernel folks have advice on how to troubleshoot this?</b>
The @Texas_Instruments Sitara AM3358 SoC in the BeagleBone has a quaduture encoded pulse decoder peripheral named eQEP. @Nathaniel_Lewis wrote a kernel driver for it:
https://github.com/Teknoman117/beaglebot/blob/master/encoders/patches/0001-tieqep-driver.patch
@Robert_Nelson has been including the patch in the BeagleBone kernel and it is working with 4.4:
https://github.com/RobertCNelson/ti-linux-kernel-dev/tree/ti-linux-4.4.y/patches/beaglebone/eqep
I'm attempting to use the eQEP driver with the 4.9.5-ti-r16:
https://github.com/RobertCNelson/ti-linux-kernel-dev/tree/ti-linux-4.9.y/patches/drivers/ti/eqep
I get a Segmentation Fault in eqep_get_position() when I read the sysfs position file:
# cat /sys/devices/platform/ocp/48304000.epwmss/48304180.eqep/position
This readl() runs OK in eqep_probe() from drivers/misc/tieqep.c:
https://github.com/RobertCNelson/ti-linux-kernel-dev/tree/ti-linux-4.9.y/patches/drivers/ti/eqep#L401
Line 697: dev_info(&pdev->dev, "QPOSCNT:0x%08x\n", readl(eqep->mmio_base + QPOSCNT));
The output is seen ok in dmesg:
[ 50.589737] eqep 48304180.eqep: eqep->mmio_base:fa304180
[ 50.590080] eqep 48304180.eqep: QPOSCNT:0x00000000
However, the same readl() causes a seg fault in eqep_get_position():
Line 401: position = readl(eqep->mmio_base + QPOSCNT);
from dmesg:
[ 1858.085381] DEBUG: tieqep.c: eqep_get_position: QPOSCNT=0
[ 1858.102133] DEBUG: tieqep.c: eqep_get_position: eqep->mmio_base=fa304180
[ 1858.108446] Unhandled fault: external abort on non-linefetch (0x1028) at 0xfa304184
These are the eqep enteries in /proc/iomem:
48300180-483001ff : /ocp/epwmss@48300000/eqep@0x48300180
48302180-483021ff : /ocp/epwmss@48302000/eqep@0x48302180
48304180-483041ff : /ocp/epwmss@48304000/eqep@0x48304180
<b>I'm not sure what the difference is. Maybe the io memory mapping changed in between the probe and reading the sysfs file?</b>
More details:
https://gist.github.com/pdp7/fe07082d23f2bfbc362c733a7b0aea72
