Originally shared by Frank Herrmann Mission accomplished :) Please check this video with the
Mission accomplished :slight_smile:
Please check this video with the new XATCv04 running. The Design is realy improved also i switched from Chilipeppr/Javascript/macro to my new REST Service @ http://xpix.eu:8080.
This means, i use now complete pure g-code. Here you can check this with follow url: http://xpix.eu:8080/xatc/replace/xatcv4/tinyg/M6%20T1/2
Read the url so, use xatc replace process and the model is xatcv4 on a tinyg Board. Put the Tool Nr.2 back and get Tool Nr.1.
Now we can use this on another CNC-Controllers like grbl, Smoothie and so on. But we need the commands M4 (rotate spindle in ccw direction) and M8/M9 (switch coolant on/off) to control servo (block/unblock) Spindle.
This Sketch on a normal arduino nano check coolant pin from tinyg and control the servo via interrupt. Works as designed :slight_smile: https://create.arduino.cc/editor/xpix/184c2dd7-aec1-40ef-8518-096d754b3f2c/preview
To control the spindle with full power i found this DC-Controller ( 3-36v Dual 15a H-bridge DC Motor Driver 30a for Robot & Car Arduino Compatible for sale online | eBay ) and put this in my 48V Power-supply enclosure, i change the output to ~41V. The Mosfet’s of this device can handle up to 52 Volt and we don’t have a battery, this means no spikes on the input and we can drive this board with higher voltage. Signals are wired:
TinyG GND => DC Controller GND
TinyG SpDir => DC Controller DIR
TinyG PWM => DC Controller PWM
TinyG 3.3V => DC Controller 5V (works also with 3.3V)
To drive this Spindle i changed my TinyG $p1 Config:
$p1frq=10000
$p1csl=100
$p1csh=12000
$p1cpl=0.05
$p1cph=0.95
$p1wsl=100
$p1wsh=12000
$p1wph=0.95
$p1wpl=0.05
$p1pof=0
So, i’ll write a Chilipeppr Widget for the XATC and hope we can use this also for other standard CNC controllers.
Please send me your opinion and comments, thanks!
Frank
@Arthur_Wolf +Peter van der Walt Look so good !!!
XATC v.04 looks really awesome. Time to build it and use with my 3040. Great job @Frank_Herrmann:ok_hand:
Great job Frank!
Many thanks friends! :smirk:
fascinating :slight_smile:
I remember the summer time, when we were drinking morning coffee in my garden and discussing with Frank how nice it would be to drink coffee while the board milling process is being run at the same time fully automatic from the beginning to the end.
Man, you really did it. No matter how many tries and errors, successes and failures you have met on your way. I appreciate your success a lot and admire your huge amount of work and time.
Please taste your success, I hope that soon we will taste some other things together, as kids are asking about uncle Frank to come again.
Congratulations, my Friend - Seb and family
Hey @sszafran many thanks for ur warm message. Yes i can say i had a great journey to poland last summer and of course a friend in warzawa :slight_smile:
Way cool.
