Originally shared by HACKADAY Lining up the beam from your homebrew (or retrofitted) laser
Lining up the beam from your homebrew (or retrofitted) laser cutter doesn’t come without its challenges. For instance, how do I use my remaining eye to align an invisible beam that has enough power to burn through some objects in its path? Some of us will…
http://hackaday.com/2016/03/10/aligning-invisible-lasers-on-the-cheap/
A little difficult to do with a K40. No room to drop in the temp mirror.
Lol… How do I use my remaining eye…
One thing I have noticed when cutting is sometimes the laser beam is visible briefly in the smoke that is given off. So I wonder, can we use some kind of fog/smoke/dust to create a visible path for while we are aligning the beam?
I am assuming a fog machine would be the best option, just not sure what kind of damage it may do to the moving parts (ie build up of a film of some sort)
