Originally shared by Kolbers.de - 3D Druck Dienstleistungen
This is far away from being a good quality print.
I have to change the retraction.
Just from the few things I can see here: You’re over-extruding. Double check your jumpers (for microstepping), recalibrate your e-steps-per-mm value, this should solve 90% of what’s going on here.
Thanks. The other printer i have is an up!mini. In the up! software there are less settings than in cura. I have to learn how to get it right.
But thanks for this tipps @ThantiK
@Kolbers.de_3D_Druck that’s true too - these could just be slicer settings that are wrong also.
@ThantiK i think so. A sample file on the original sd card of the printer was printed better.
