Originally shared by MatterHackers
Trying to find the right filament for your next project? Look no further! From standard to specialty, we have created a brand new filament guide that will teach you about over 25 different types of filament!
http://www.matterhackers.com/3d-printer-filament-compare
Got some errors in the printing/bed temps. EG, bed temp for ABS and HIPS are way too low, should be 80-100C. ABS print temp is too low. Print temp for PC is a little high, 260-280C is way more common than 300C, but the bed temp is too low, it’s normally in the 100-130C range depending on the adhesive used. 190C is too high for PVA in many printers, it’ll turn to tar. Flexibles don’t require any bed heat at all, there’s no warping stress.
Other note, Proto-Pasta’s CFR-PLA is NOT stronger than regular PLA, it actually has reduced strength. It’s just very, very stiff.
Thank you! These corrections have been made.
