Originally shared by Michel Pollet CNC Progress, assembled, adjusted, added endstop microswitches,
CNC Progress, assembled, adjusted, added endstop microswitches, with rather neatly placed filtering caps… And started to play with the TinyG2 on the arduidiot Due + gShield v5. Wired the supply.
Next is to try to move the motors, and install the belts!
Any luck getting TinyG2 running on the Due? I tried using the edge branch today and I can build and flash fine. But it doesn’t seem to run. No flashing orange led. I don’t have my shield yet so I’m just running the Due.
Funnily enough, I’ve just filed a bug. ran into that problem too… Serial port appear, but nothing on them. Bit wierd
Make sure to add your grain of salt there, if you have other details or even as a ‘me too’ :slight_smile:
PathCAM?
LOL! Happends when you have about 12 tabs on github :slight_smile:
Pfew :slight_smile:
I’ve been having a bit of a conversation at the end of https://github.com/synthetos/g2/issues/47
Looks like it might be toolchain related.
Actually my G2 is compiled with the ‘Tools’ version they download, and I got the same warning and failure as you do…
