Originally shared by Paolo Negrini What happens when you mix belated spring cleaning and
What happens when you mix belated spring cleaning and 3D printing?
A practical solution to keep any box closed! Have a look at the source design on Github: https://github.com/pfnegrini/boxTightener.git
#3dprinting
Box tightener by Cap-n-Proud - Thingiverse
I had to read this 4 times before I realized the spring you were talking about wasn’t an extruder spring for tensioning.
@Adam_Steinmark Respect, but you’re not a true 3D Printer fanatic until you wake up and use your printer LCD’s thermistor readout to check the ambient temperature of your house.
Wow! This is an idea. Thanks! It actually works and can probably used to measure fever as well. Fast and effective.
by the way it’s now 30 degree Celsius in Zurich
@raykholo Oh I don’t want to check the ambient temp. The ventilation shaft to my room is currently in repair so summer + 3D printer = room sauna.
Between 25 and 27 here in northern NJ.
@raykholo between 30 and 31 in my room in northern NJ
@Paolo_Negrini printed on glass bed with glue stick or similar?
@Electra: yes, I used an Ultimaker 2 with heated glass bed and glue stick. Material is PLA, 40%infill 0.8 shell thickness @195C
