Originally shared by Walter K (opaque) What is the reason for the jagged cutting
What is the reason for the jagged cutting lines. Too much teeth (GT2 pulley with 30 tooth) or belt tension or microsteps (Nema17 with 1/16) or PWM Hz?
How fast are you trying to cut at?
@Alex_Krause 5mm/sec
What are the best settings in grbl 1.1e / cpu_map.h for a laserdriver with this specifications:
Model: SHS-2500
Current (mA): 2500
Supply Voltage (VDC): 3~24
Modulation (kHz Analog / kHz TTL): 500 / 250
Modulation Voltage (VDC): 0~5
Rise-Fall-Time (μs): 1.4
Noise (mV): 1.6
cpu_map.h:
// Prescaled, 8-bit Fast PWM mode.
#define SPINDLE_TCCRA_INIT_MASK ((1<<WGM20) | (1<<WGM21)) // Configures fast PWM mode.
// #define SPINDLE_TCCRB_INIT_MASK (1<<CS20) // Disable prescaler → 62.5kHz
// #define SPINDLE_TCCRB_INIT_MASK (1<<CS21) // 1/8 prescaler → 7.8kHz (Used in v0.9)
// #define SPINDLE_TCCRB_INIT_MASK ((1<<CS21) | (1<<CS20)) // 1/32 prescaler → 1.96kHz
#define SPINDLE_TCCRB_INIT_MASK (1<<CS22) // 1/64 prescaler → 0.98kHz (J-tech laser)
After a test with 5V from a battery with the same result, now I changed my pulleys to 20 teeth (before 30) and the jagged cutting lines are history.
