OX running at 40k mm/min. 1.2 seconds to go 710mm. Acceleration is 1300. Motors can’t go much higher then that.
https://www.instagram.com/p/BHw4R-fA92N/
Highly advise you do some circular movement tests at those settings. I found while I could turn up the speed on single axis moves as soon as you go at diagonals the forces are such that you can’t go quite as fast.
This obviously isn’t for cutting purposes, more of a stress test. Diagonals will only be slower because it will have to go as fast as the slowest axis (the shortest one)
Even on just travel moves I found that the torque involved in moving two axes caused increased friction which resulted in stalling at high speeds on diagonals. Anyway point being is to test this sort of change out on a more complex path, not just straight line travels.
