Thanks! Using your example and the copy of FastLED you included in it, I can compile both your test, as well as demoreel100. I will need to rewire my project before I can test it.
However, If I download the master and set it up the directory structure just like yours I get errors.
For now, I guess I can just use the version that you provided. At some point I may try to figure out what is happening, but these tools suck!
The current master doesn’t support Photon. You need to use one of the several ports that exist. I find that Eclipse with a local copy of FastLED works best though. You can find a lot of different how-to’s for getting Photon building with Eclipse.
