@Paul_de_Groot All I get from CNCj is the following when sending ?
Idle|MPos:0.000,0.000,0.000|Bf:15,127|FS:0,0> when $5=1
<Idle|MPos:0.000,0.000,0.000|Bf:15,127|FS:0,0|Pn:XYZ> when $5=0 does this mean anything to you?
This is my settings as they stand
$0=10 (Step pulse time, microseconds)
$1=255 (Step idle delay, milliseconds)
$2=0 (Step pulse invert, mask)
$3=3 (Step direction invert, mask)
$4=0 (Invert step enable pin, boolean)
$5=0 (Invert limit pins, boolean)
$6=0 (Invert probe pin, boolean)
$10=31 (Status report options, mask)
$11=0.010 (Junction deviation, millimeters)
$12=0.002 (Arc tolerance, millimeters)
$13=0 (Report in inches, boolean)
$20=0 (Soft limits enable, boolean)
$21=0 (Hard limits enable, boolean)
$22=1 (Homing cycle enable, boolean)
$23=3 (Homing direction invert, mask)
$24=600.000 (Homing locate feed rate, mm/min)
$25=1000.000 (Homing search seek rate, mm/min)
$26=250 (Homing switch debounce delay, milliseconds)
$27=2.500 (Homing switch pull-off distance, millimeters)
$28=0.000
$30=2048 (Maximum spindle speed, RPM)
$31=5 (Minimum spindle speed, RPM)
$32=1 (Laser-mode enable, boolean)
$100=160.000 (X-axis travel resolution, step/mm)
$101=160.000 (Y-axis travel resolution, step/mm)
$102=250.000 (Z-axis travel resolution, step/mm)
$110=10000.000 (X-axis maximum rate, mm/min)
$111=10000.000 (Y-axis maximum rate, mm/min)
$112=500.000 (Z-axis maximum rate, mm/min)
$120=3000.000 (X-axis acceleration, mm/sec^2)
$121=3000.000 (Y-axis acceleration, mm/sec^2)
$122=10.000 (Z-axis acceleration, mm/sec^2)
$130=320.000 (X-axis maximum travel, millimeters)
$131=230.000 (Y-axis maximum travel, millimeters)
$132=200.000 (Z-axis maximum travel, millimeters)
ok
