Peltier cooling system part 4 “ uhh ohh …starting over”
I’ve spent a lot of time trying to understand the cooling power of the 180 watt Pelter bank I have. I’ve had to admit to myself of being a bit overwhelmed at first when trying to put together all the numbers. It seemed every time I learn more about how Pelteir’s work and the thermodynamics involved in setting this system up, I find something I missed, so now in saying that I’ve thrown out all the numbers I posted in part 3… and I’ve had to start over.
One important issue I badly messed up was the amount of coolant I’m trying cool, plus cool down time, in the beginning. I abandoned the insulated 5 gallon red tank I built because there was just no reasonable way to cool down that much water with even double the Peltiers I have without leaving the system on almost continuously. I’m down to working on a system that has about 3.5 liters of coolant total in it. This should allow me a much shorter cool down time to operating temperature and also enough heat carrying capacity to move it to the Peltier system and away from the laser tube.
The heat the laser generates during use is not static but varies with how your using it. The tube when firing is putting out 13000 to 20000 volts so and at 12 ma that is up to 240 watts of heat to control! Also, it is important we have to know the ‘duty cycle’ (“The cycle of operation of a machine or other device that operates intermittently rather than continuously. The time occupied by the cycle of operation of a machine or other device, especially as a percentage of available time is called the ‘Duty Cycle’”.)
I had to come up with some number so I decided 200 watts was the average heat flow I was going to use and the duty cycle was 50%. This means I need to get rid of 100 watts of heat when running. Sometimes more and sometimes less over a given run period just for the laser.
In the system I’m building my belief is the water volume of the system without the tank reserve is about a liter and the balance of two point two five liters of water as my buffer in the tank to allow for any short periods of wattage over the duty cycle and recovery time when it is below the duty cycle.
I started looking at where ‘heat flow’ (other than the laser active tube) would be coming from. Surprisingly there is a lot in the system environment absorbed or generated by the pump, tank walls, tubing, and other things surrounding the system and coolant.
Your shop temperature too is a big factor in what is needed to control the laser’s coolant temperature. My shop stays from 19C to 27C most of the time and the humidity rarely exceeds 35%. The other day it was really hot outside, 40.5C (close to a record). But because the shop is well insulted and the bottom of a two story building I only measured 28.3C inside this means that if I want to keep the laser tube between 16C and 22C I have to consider worst case of the environmental temperature difference. In this case it was 6.3C.
A submerged water pump can be a significant contributing factor for some of these systems. Example, the submergible pump the K40 came with generates about 5 to 8 watts, but if you’re using an aftermarket submergible, they could be generating much more… some as much as 20 watts . So using a bigger, higher flow pump may add more heat than it is worth if it is submerged. I’m not using a submerged pump so I only have to worry about the ‘heat flow’ through its magnetic drive to the impeller as long as I position the motor away from and not in contact with the rest of the system .
I’ve looked at a bunch of ways to figure out just what the system heat gain is and in the end it came down to some formulas and the rest guess work… but with the laser tube off I’ve settled on just a hair under 1 watt/sq in as an average and I have about 200 sq/in of surface area in the system. That’s 200 watts of constant heat flow average being absorbed because of a 4C temperature difference between the desired operating coolant temperature and what the environment is trying to pass into the system. By insulating the tank, tubing and so forth I’m hoping to cut the heat absorption there by 50%.
So if my numbers are right, I would need a cooling capacity of about 200 watts for the whole laser cooling system. Well I don’t have 200 watts of cooling capacity right now. I only have the 180 watt Peltier bank and that outputs just 126 watts of functional cooling. So in the end I’ve ordered another Peltier bank the same as the first. Now it’s a wait for the unit (2 to 3 weeks), another transformer and the relay (1 week). Fortunately the electrical box, and coolant box I’ve made will hold the additional unit and electrical.
I believe 252 watts should be enough if am right on my calculations but the only way I’ll know sure is to put it all together and see what I get. Once it is running I can get some hard numbers to post as I use the laser.
