PID failure
So the problem is that if I use the kill button, while the Hot End PID is heating up, then initiate the BED PID, The Hot end will continue to heat up way past the 310 cut off I have set for the printer(it normally shuts down if it goes to 310).
The printer went up over 800 degrees Celsius when I shut the machine down. Is this a hardware issue? When I initiated the kill button on my viki2 screen it sounded like it stopped as the fans turned off. Is there a way to get the PID tuning to stop at a certain point? or is there a way to make sure that it stops in the config? or a system fail safe to not go over 310 in this situation? Thanks.
