please give me the working adalight code teensy3.1 13 green,
13 green, 11 blue GND GND connections
no responseDo not answer LEDs
adalight
Arduino working code does not work teensy3.1
  • A ‘fork’ of the adalight code, with a nice case statement.
  • Tested with the LPD6803 50 led string
  • should work with the WS2801 as well
    #include “FastSPI_LED.h”
#define NUM_LEDS 110
  • pin 11 → blue for the LPD6803 ‘yellow’ for the WS2801 string
  • pin 13 → green for the LPD6803 ‘green’ for the WS2801 string
#define PIN 4
#define MODE_HDRA 0
#define MODE_HDRd 1
#define MODE_HDRa 2
#define MODE_HDRhi 3
#define MODE_HDRlo 4
#define MODE_HDRchk 5
#define MODE_DATAr 6
#define MODE_DATAg 7
#define MODE_DATAb 8
// Sometimes chipsets wire in a backwards sort of way
struct CRGB { unsigned char r; unsigned char b; unsigned char g; };
struct CRGB *leds;
unsigned long t,
startTime,
lastByteTime,
lastAckTime;
uint8_t hi, lo, chk,
mode = MODE_HDRA;
int channels,channel;
void setup()
Serial.begin(115200);
FastSPI_LED.setLeds(NUM_LEDS);
//Change this to match your led strip
FastSPI_LED.setChipset(CFastSPI_LED::SPI_LPD6803);
//FastSPI_LED.setChipset(CFastSPI_LED::SPI_TM1809);
//FastSPI_LED.setChipset(CFastSPI_LED::SPI_HL1606);
//FastSPI_LED.setChipset(CFastSPI_LED::SPI_595);
//FastSPI_LED.setChipset(CFastSPI_LED::SPI_WS2801);
FastSPI_LED.setPin(PIN);
//Change datarate to match your led strip as well
FastSPI_LED.setDataRate(3);
FastSPI_LED.init();
FastSPI_LED.start();
leds = (struct CRGB*)FastSPI_LED.getRGBData();
clearLeds();
Serial.print(“Ada\n”);
lastByteTime = startTime = lastAckTime = millis();
int readByte(){
while(Serial.available()==0){
//FastSPI_LED.stop();
//FastSPI_LED.start();
return Serial.read();
void clearLeds(){
memset(leds, 0, NUM_LEDS * 3);
FastSPI_LED.show();
delay(20);
void loop(){
int16_t c;
c = readByte();
t = millis();
if((t - lastAckTime) > 1000) {
Serial.print(“Ada\n”); // Send ACK string to host
lastAckTime = t; // Reset counter
if ((t - lastByteTime) > 5000) {
mode = MODE_HDRA; // After 5 seconds reset to HDRA
lastByteTime = t;
lastAckTime = t;
switch(mode){
case MODE_HDRA:
if (c == 0x41) {
mode = MODE_HDRd;
break;
case MODE_HDRd:
if (c == 0x64) {
mode = MODE_HDRa;
break;
case MODE_HDRa:
if (c == 0x61) {
mode = MODE_HDRhi;
break;
case MODE_HDRhi:
hi = c;
mode = MODE_HDRlo;
break;
case MODE_HDRlo:
lo = c;
mode = MODE_HDRchk;
break;
case MODE_HDRchk:
chk = c;
if (chk == (hi ^ lo ^ 0x55)){
mode = MODE_DATAr;
channels = (long)hi*256+(long)lo;
channel = 0;
} else {
// wrong checksum, reset header
mode = MODE_HDRA;
break;
case MODE_DATAr:
// we are in the data business :wink:
// ignore all data for channels higher than NUM_LEDS
if (channel<NUM_LEDS) { leds[channel].r = c; }
mode = MODE_DATAb;
break;
case MODE_DATAb:
if (channel<NUM_LEDS) { leds[channel].b = c; }
mode = MODE_DATAg;
break;
case MODE_DATAg:
if (channel<NUM_LEDS) { leds[channel].g = c; }
channel++;
if (channel>channels) {
FastSPI_LED.show();
mode = MODE_HDRA;
} else {
mode = MODE_DATAr;
break;
default:
// I should not be here, back to
mode = MODE_HDRA;
FastLED no longer supports the LPD6803 chipset.
I don’t have it, as I don’t use adalight.
Also - what led chipset are you using?
And again, the FastLED library no longer supports the LPD6803. You need different leds.
You are using a 3 year old version of the library that isn’t supported anymore, and with google code going away, isn’t even available anymore.
So, what do you think about this cause 120 led Arduino uno bound state
I don’t know - I don’t use adalight at all, and you’re using a version of the library that I haven’t looked at in 2+ years.
You should probably ask on the adafruit forums for help with adalight.
Thank you okay
