Popped a fuse.  Damn.
Popped a fuse. Damn. Now I have to go buy a fuse >_> I haven’t a clue what size this thing takes.
Do you know what caused the fuse to blow? You might wanna look into it, because it’ll most likely blow again immediately.
That’s not a good sign for a machine only a few hours old! You should probably investigate it, sometimes the Chinese wiring can be questionable!
I do know what caused it, actually. Completely my fault.
Ahh gotcha. I’m not near my unit, so I can’t tell you what size fuse it uses
I changed up the wiring a bit to use standard buss fuses. should work out better.
