Hi
I have Delta printer and a electronics boards using Smoothiware been quite happy with the firmware ….anyways in my wisdom(or not) I purchased the Replicape cape that goes with a Beaglebone Black as I liked the specs and thought it would be good now and for the future. Spec wise the combination is hard to beat.
Redeem is the firmware ….sorry I cant post a link
Replicape is the control board ……sorry I cant post a link
I can not fault the hardware but the software is well good in some aspects somewhat wanting in others.
I must point out I am a user not a programmer so this is based from a user point of view.
I understand that the path planner was based on Repetier and I am not sure why that was chosen instead of maybe Smoothieware. I think smoothie would have been a more up todate and cleaner base?
I am asking is it possible to port your firmware to this hardware and if it can be … can you give me pointers on how I would achieve that goal.
I am not a programmer so I suspect my learning curve will be huge.
Thanks
