Preparing for Z probing with switch:
Servo range is 180 degrees. Any ideas why its going only in about 170 degrees range? I use M280 P0 S180 command.
Different servo brands have different pwm settings for neutral. Maybe it needs to be adjusted?
You can set the pulse length in the settings file, so if it works with a different controller, you can recreate that with redeem!
