Printer disconnects randomly
Hey all
Ive been using my smoothieboard for a good month without issue but after designing a very simple file on Fusion 360 im getting some really odd disconnects.
I have been slicing with S3D then transferring to SD and printing from that. The print will be going perfectly fine then somtimes at 2 minutes or as far in as 20 minutes the print just freezes in position and returns “WARNING: Device unplugged while connected to port”. I tried to isolate the issue by trying other files and they printed fine a 5 hour print using the same S3D profile and did not freeze up. This indicated that its unlikely a USB issue, SD card issue, S3D setting issue. But the same file redesigned from scratch and attempted again still failed. Ive attached the gcode for one of the files which will randomly freeze up during the print and my config file
Can you please make sure you are using :
  • The very latest version of S3D
  • The very latest of the Smoothie firmware’s edge branch
  • The very latest config file example ( port your values over to it )
And then try again.
Thanks.
Just did all of that and used smoothieware firmware from 11 days ago. Not exactly sure if it was the edge branch though. Were there changes that might help remedy my predicament in later firmwares or are we just trying to establish a common start point? Trying the same print out now.
Gotcha, so ran everything again and had the same lock up after the first 2 layers. During my googling I did find that there is something termed as hardware flow control/ software flow control in S3D. Would it help to enable that? I am trying to print from another computer to see if it also causes a stop with the new firmware now.
Doesn’t hurt to try.
Also please try printing the same file, but with Pronterface, as a test.
Decided to once and for all get away from USB and based on the fact that pronterface is known to work consistently with smoothie I decided to give it another go all together.
I enabled the network settings again for my board and while I was having problems with the functionality of the web interface connecting through pronterface seems to be great. In fact as reluctant as I was to add another program to the printing workflow pronterface has some nice benefits over S3Ds monitoring of gcode. I can actually see a completed percent while the print is occuring!
Im gonna let this problem print run overnight and check in when I wake up to see if I get any dropped connections.
Few questions about printing via pronterface if anyone can answer and save me from posting on reddit or making a new thread.
1.If I start a SD card print via pronterface and out of filament detection is triggered can I resume from pronterface?
2.If I close pronterface after starting an SD card print will it continue printing and can I reconnect at a later time to see the status?
3. Are the time predictions accurate or is the % a better indicator of how much of the print remains?
Thanks!
Yarg when I start a print that isnt from SD and is just a loaded file I keep getting this error
[ERROR] Can’t write to printer (disconnected ?):
Traceback (most recent call last):
File “printrun\printcore.pyc”, line 608, in _send
File “socket.pyc”, line 324, in write
File “socket.pyc”, line 303, in flush
timeout: timed out
The print continues but it disconnects pronterface and when I restart I can watch the temperature but cant pause or do much else to the print going on
; G-Code generated by Simplify3D(R) Version 3.1.1
; Dec 25, 2016 at 2:57:24 AM
; Settings Summary
;   processName,Process2
;   applyToModels,timeline1
;   profileName,0.8VASE[1000]WHITEPLA (modified)
;   profileVersion,2016-12-07 20:23:45
;   baseProfile,Gigabot 0_4 Nozzle (modified)
;   printMaterial,PLA
;   printQuality,Medium
;   printExtruders,
;   extruderName,Primary Extruder
;   extruderToolheadNumber,0
;   extruderDiameter,0.8
;   extruderAutoWidth,0
;   extruderWidth,0.8
;   extrusionMultiplier,1.1
;   extruderUseRetract,1
;   extruderRetractionDistance,0.6
;   extruderExtraRestartDistance,0.15
;   extruderRetractionZLift,0.5
;   extruderRetractionSpeed,3600
;   extruderUseCoasting,0
;   extruderCoastingDistance,0
;   extruderUseWipe,0
;   extruderWipeDistance,2.5
;   primaryExtruder,0
;   layerHeight,0.6
;   topSolidLayers,3
;   bottomSolidLayers,2
;   perimeterOutlines,1
;   printPerimetersInsideOut,1
;   startPointOption,3
;   startPointOriginX,196
;   startPointOriginY,0
;   startPointOriginZ,309
;   sequentialIslands,0
;   spiralVaseMode,0
;   firstLayerHeightPercentage,100
;   firstLayerWidthPercentage,100
;   firstLayerUnderspeed,0.45
;   useRaft,0
;   raftExtruder,0
;   raftLayers,1
;   raftOffset,3
;   raftSeparationDistance,0.18
;   raftInfill,60
;   disableRaftBaseLayers,0
;   useSkirt,1
;   skirtExtruder,0
;   skirtLayers,1
;   skirtOutlines,1
;   skirtOffset,10
;   usePrimePillar,0
;   primePillarExtruder,999
;   primePillarWidth,12
;   primePillarLocation,7
;   primePillarSpeedMultiplier,1
;   useOozeShield,0
;   oozeShieldExtruder,999
;   oozeShieldOffset,2
;   oozeShieldOutlines,1
;   oozeShieldSidewallShape,1
;   oozeShieldSidewallAngle,30
;   oozeShieldSpeedMultiplier,1
;   infillExtruder,0
;   internalInfillPattern,Rectilinear
;   externalInfillPattern,Concentric
;   infillPercentage,13
;   outlineOverlapPercentage,37
;   infillExtrusionWidthPercentage,110
;   minInfillLength,5
;   infillLayerInterval,1
;   infillAngles,45,-45
;   overlapInfillAngles,0
;   generateSupport,0
;   supportExtruder,0
;   supportInfillPercentage,20
;   supportExtraInflation,0
;   denseSupportLayers,2
;   denseSupportInfillPercentage,70
;   supportLayerInterval,1
;   supportHorizontalPartOffset,0.85
;   supportUpperSeparationLayers,1
;   supportLowerSeparationLayers,1
;   supportType,0
;   supportGridSpacing,4
;   maxOverhangAngle,45
;   supportAngles,45
;   temperatureName,Primary Extruder
;   temperatureNumber,0
;   temperatureSetpointCount,1
;   temperatureSetpointLayers,1
;   temperatureSetpointTemperatures,27
;   temperatureStabilizeAtStartup,1
;   temperatureHeatedBed,0
;   temperatureRelayBetweenLayers,0
;   temperatureRelayBetweenLoops,0
;   fanLayers,2
;   fanSpeeds,100
;   blipFanToFullPower,0
;   adjustSpeedForCooling,0
;   minSpeedLayerTime,8
;   minCoolingSpeedSlowdown,30
;   increaseFanForCooling,0
;   minFanLayerTime,45
;   maxCoolingFanSpeed,100
;   increaseFanForBridging,0
;   bridgingFanSpeed,75
;   use5D,1
;   relativeEdistances,0
;   allowEaxisZeroing,1
;   independentExtruderAxes,0
;   includeM10123,0
;   stickySupport,1
;   applyToolheadOffsets,0
;   gcodeXoffset,0
;   gcodeYoffset,0
;   gcodeZoffset,0.15
;   overrideMachineDefinition,1
;   machineTypeOverride,0
;   strokeXoverride,600
;   strokeYoverride,600
;   strokeZoverride,600
;   originOffsetXoverride,0
;   originOffsetYoverride,0
;   originOffsetZoverride,0
;   homeXdirOverride,-1
;   homeYdirOverride,-1
;   homeZdirOverride,-1
;   flipXoverride,1
;   flipYoverride,-1
;   flipZoverride,1
;   toolheadOffsets,0,0|0,0|0,0|0,0|0,0|0,0
;   overrideFirmwareConfiguration,0
;   firmwareTypeOverride,RepRap (Marlin/Repetier/Sprinter)
;   GPXconfigOverride,r2
;   baudRateOverride,250000
;   overridePrinterModels,0
;   printerModelsOverride
;   startingGcode,M220 S100,M221 S100,G28,G92 E0,
;   layerChangeGcode,
;   retractionGcode,
;   toolChangeGcode,
;   endingGcode,M104 S0 ; turn off temperature,M190 S0,G28 X0 Y0,M18;,G4 P180000,M107
;   exportFileFormat,gcode
;   celebration,0
;   celebrationSong,Funky Town
;   postProcessing,
;   defaultSpeed,1000
;   outlineUnderspeed,0.8
;   solidInfillUnderspeed,0.7
;   supportUnderspeed,0.8
;   rapidXYspeed,9000
;   rapidZspeed,275
;   minBridgingArea,50
;   bridgingExtraInflation,0
;   bridgingExtrusionMultiplier,1
;   bridgingSpeedMultiplier,1
;   filamentDiameter,1.75
;   filamentPricePerKg,30
;   filamentDensity,1.25
;   useMinPrintHeight,0
;   minPrintHeight,0
;   useMaxPrintHeight,0
;   maxPrintHeight,0.6
;   useDiaphragm,0
;   diaphragmLayerInterval,20
;   robustSlicing,1
;   mergeAllIntoSolid,0
;   onlyRetractWhenCrossingOutline,0
;   retractBetweenLayers,0
;   useRetractionMinTravel,0
;   retractionMinTravel,3
;   retractWhileWiping,1
;   onlyWipeOutlines,1
;   avoidCrossingOutline,0
;   maxMovementDetourFactor,3
;   toolChangeRetractionDistance,12
;   toolChangeExtraRestartDistance,-0.5
;   toolChangeRetractionSpeed,600
;   allowThinWallGapFill,1
;   thinWallAllowedOverlapPercentage,10
;   horizontalSizeCompensation,0
G90
M82
M104 S27 T0
M109 S27 T0
M220 S100
M221 S100
G28
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z1.250 F275
; layer 1, Z = 0.6
T0
; tool H0.600 W0.800
; skirt
G1 X258.131 Y289.661 F9000
G1 Z0.750 F275
G1 E0.1500 F1080
G92 E0
G1 X258.278 Y289.600 E0.0349 F450
G1 X341.722 Y289.600 E18.3522
G1 X341.869 Y289.661 E18.3871
G1 X347.839 Y295.631 E20.2406
G1 X347.900 Y295.778 E20.2755
G1 X347.900 Y344.222 E30.9096
G1 X347.839 Y344.369 E30.9446
G1 X341.869 Y350.339 E32.7980
G1 X341.722 Y350.400 E32.8330
G1 X258.278 Y350.400 E51.1502
G1 X258.131 Y350.339 E51.1851
G1 X252.161 Y344.369 E53.0386
G1 X252.100 Y344.222 E53.0735
G1 X252.100 Y295.778 E63.7077
G1 X252.161 Y295.631 E63.7426
G1 X258.131 Y289.661 E65.5961
G92 E0
G1 E-0.6000 F3600
G1 Z1.250 F275
; outer perimeter
G1 X262.900 Y300.400 F9000
G1 Z0.750 F275
G1 E0.1500 F3600
G92 E0
G1 X337.100 Y300.400 E16.2882 F360
G1 X337.100 Y339.600 E24.8932
G1 X262.900 Y339.600 E41.1814
G1 X262.900 Y300.400 E49.7864
G92 E0
G1 E-0.6000 F3600
G1 Z1.250 F275
; solid layer
G1 X263.404 Y300.904 F9000
G1 Z0.750 F275
G1 E0.1500 F3600
G92 E0
G1 X336.596 Y300.904 E16.0669 F315
G1 X336.596 Y339.096 E24.4507
G1 X263.404 Y339.096 E40.5176
G1 X263.404 Y300.904 E48.9013
G92 E0
G1 E-0.6000 F3600
G1 Z1.250 F275
G1 X264.204 Y301.704 F9000
G1 Z0.750 F275
G1 E0.1500 F3600
G92 E0
G1 X335.796 Y301.704 E15.7157 F315
G1 X335.796 Y338.296 E23.7482
G1 X264.204 Y338.296 E39.4639
G1 X264.204 Y301.704 E47.4964
G92 E0
G1 E-0.6000 F3600
G1 Z1.250 F275
G1 X265.004 Y302.504 F9000
G1 Z0.750 F275
G1 E0.1500 F3600
G92 E0
G1 X334.996 Y302.504 E15.3644 F315
G1 X334.996 Y337.496 E23.0458
G1 X265.004 Y337.496 E38.4102
G1 X265.004 Y302.504 E46.0915
G92 E0
G1 E-0.6000 F3600
G1 Z1.250 F275
G1 X265.804 Y303.304 F9000
G1 Z0.750 F275
G1 E0.1500 F3600
G92 E0
G1 X334.196 Y303.304 E15.0132 F315
G1 X334.196 Y336.696 E22.3433
G1 X265.804 Y336.696 E37.3565
G1 X265.804 Y303.304 E44.6866
G92 E0
G1 E-0.6000 F3600
G1 Z1.250 F275
G1 X266.604 Y304.104 F9000
G1 Z0.750 F275
G1 E0.1500 F3600
G92 E0
G1 X333.396 Y304.104 E14.6620 F315
G1 X333.396 Y335.896 E21.6409
G1 X266.604 Y335.896 E36.3028
G1 X266.604 Y304.104 E43.2817
G92 E0
G1 E-0.6000 F3600
G1 Z1.250 F275
G1 X267.404 Y304.904 F9000
G1 Z0.750 F275
G1 E0.1500 F3600
G92 E0
G1 X332.596 Y304.904 E14.3107 F315
G1 X332.596 Y335.096 E20.9384
G1 X267.404 Y335.096 E35.2491
G1 X267.404 Y304.904 E41.8768
G92 E0
G1 E-0.6000 F3600
G1 Z1.250 F275
G1 X268.204 Y305.704 F9000
G1 Z0.750 F275
G1 E0.1500 F3600
G92 E0
G1 X331.796 Y305.704 E13.9595 F315
G1 X331.796 Y334.296 E20.2359
G1 X268.204 Y334.296 E34.1955
G1 X268.204 Y305.704 E40.4719
G92 E0
G1 E-0.6000 F3600
G1 Z1.250 F275
G1 X269.004 Y306.504 F9000
G1 Z0.750 F275
G1 E0.1500 F3600
G92 E0
G1 X330.996 Y306.504 E13.6083 F315
G1 X330.996 Y333.496 E19.5335
G1 X269.004 Y333.496 E33.1418
G1 X269.004 Y306.504 E39.0670
G92 E0
G1 E-0.6000 F3600
G1 Z1.250 F275
G1 X269.804 Y307.304 F9000
G1 Z0.750 F275
G1 E0.1500 F3600
G92 E0
G1 X330.196 Y307.304 E13.2571 F315
G1 X330.196 Y332.696 E18.8310
G1 X269.804 Y332.696 E32.0881
G1 X269.804 Y307.304 E37.6621
G92 E0
G1 E-0.6000 F3600
G1 Z1.250 F275
G1 X270.604 Y308.104 F9000
G1 Z0.750 F275
G1 E0.1500 F3600
G92 E0
G1 X329.396 Y308.104 E12.9058 F315
G1 X329.396 Y331.896 E18.1286
G1 X270.604 Y331.896 E31.0344
G1 X270.604 Y308.104 E36.2572
G92 E0
G1 E-0.6000 F3600
G1 Z1.250 F275
G1 X271.404 Y308.904 F9000
G1 Z0.750 F275
G1 E0.1500 F3600
G92 E0
G1 X328.596 Y308.904 E12.5546 F315
G1 X328.596 Y331.096 E17.4261
G1 X271.404 Y331.096 E29.9807
G1 X271.404 Y308.904 E34.8523
G92 E0
G1 E-0.6000 F3600
G1 Z1.250 F275
G1 X272.204 Y309.704 F9000
G1 Z0.750 F275
G1 E0.1500 F3600
G92 E0
G1 X327.796 Y309.704 E12.2034 F315
G1 X327.796 Y330.296 E16.7237
G1 X272.204 Y330.296 E28.9271
G1 X272.204 Y309.704 E33.4474
G92 E0
G1 E-0.6000 F3600
G1 Z1.250 F275
G1 X273.004 Y310.504 F9000
G1 Z0.750 F275
G1 E0.1500 F3600
G92 E0
G1 X326.996 Y310.504 E11.8522 F315
G1 X326.996 Y329.496 E16.0212
G1 X273.004 Y329.496 E27.8734
G1 X273.004 Y310.504 E32.0424
G92 E0
G1 E-0.6000 F3600
G1 Z1.250 F275
G1 X273.804 Y311.304 F9000
G1 Z0.750 F275
G1 E0.1500 F3600
G92 E0
G1 X326.196 Y311.304 E11.5009 F315
G1 X326.196 Y328.696 E15.3188
G1 X273.804 Y328.696 E26.8197
G1 X273.804 Y311.304 E30.6375
G92 E0
G1 E-0.6000 F3600
G1 Z1.250 F275
G1 X274.604 Y312.104 F9000
G1 Z0.750 F275
G1 E0.1500 F3600
G92 E0
G1 X325.396 Y312.104 E11.1497 F315
G1 X325.396 Y327.896 E14.6163
G1 X274.604 Y327.896 E25.7660
G1 X274.604 Y312.104 E29.2326
G92 E0
G1 E-0.6000 F3600
G1 Z1.250 F275
G1 X275.404 Y312.904 F9000
G1 Z0.750 F275
G1 E0.1500 F3600
G92 E0
G1 X324.596 Y312.904 E10.7985 F315
G1 X324.596 Y327.096 E13.9139
G1 X275.404 Y327.096 E24.7123
G1 X275.404 Y312.904 E27.8277
G92 E0
G1 E-0.6000 F3600
G1 Z1.250 F275
G1 X276.204 Y313.704 F9000
G1 Z0.750 F275
G1 E0.1500 F3600
G92 E0
G1 X323.796 Y313.704 E10.4472 F315
G1 X323.796 Y326.296 E13.2114
G1 X276.204 Y326.296 E23.6587
G1 X276.204 Y313.704 E26.4228
G92 E0
G1 E-0.6000 F3600
G1 Z1.250 F275
G1 X277.004 Y314.504 F9000
G1 Z0.750 F275
G1 E0.1500 F3600
G92 E0
G1 X322.996 Y314.504 E10.0960 F315
G1 X322.996 Y325.496 E12.5090
G1 X277.004 Y325.496 E22.6050
G1 X277.004 Y314.504 E25.0179
G92 E0
G1 E-0.6000 F3600
G1 Z1.250 F275
G1 X277.804 Y315.304 F9000
G1 Z0.750 F275
G1 E0.1500 F3600
G92 E0
G1 X322.196 Y315.304 E9.7448 F315
G1 X322.196 Y324.696 E11.8065
G1 X277.804 Y324.696 E21.5513
G1 X277.804 Y315.304 E23.6130
G92 E0
G1 E-0.6000 F3600
G1 Z1.250 F275
G1 X278.604 Y316.104 F9000
G1 Z0.750 F275
G1 E0.1500 F3600
G92 E0
G1 X321.396 Y316.104 E9.3936 F315
G1 X321.396 Y323.896 E11.1040
G1 X278.604 Y323.896 E20.4976
G1 X278.604 Y316.104 E22.2081
G92 E0
G1 E-0.6000 F3600
G1 Z1.250 F275
G1 X279.404 Y316.904 F9000
G1 Z0.750 F275
G1 E0.1500 F3600
G92 E0
G1 X320.596 Y316.904 E9.0423 F315
G1 X320.596 Y323.096 E10.4016
G1 X279.404 Y323.096 E19.4439
G1 X279.404 Y316.904 E20.8032
G92 E0
G1 E-0.6000 F3600
G1 Z1.250 F275
G1 X280.204 Y317.704 F9000
G1 Z0.750 F275
G1 E0.1500 F3600
G92 E0
G1 X319.796 Y317.704 E8.6911 F315
G1 X319.796 Y322.296 E9.6991
G1 X280.204 Y322.296 E18.3903
G1 X280.204 Y317.704 E19.3983
G92 E0
G1 E-0.6000 F3600
G1 Z1.250 F275
G1 X281.004 Y318.504 F9000
G1 Z0.750 F275
G1 E0.1500 F3600
G92 E0
G1 X318.996 Y318.504 E8.3399 F315
G1 X318.996 Y321.496 E8.9967
G1 X281.004 Y321.496 E17.3366
G1 X281.004 Y318.504 E17.9934
G92 E0
G1 E-0.6000 F3600
G1 Z1.250 F275
G1 X281.804 Y319.304 F9000
G1 Z0.750 F275
G1 E0.1500 F3600
G92 E0
G1 X318.196 Y319.304 E7.9887 F315
G1 X318.196 Y320.696 E8.2942
G1 X281.804 Y320.696 E16.2829
G1 X281.804 Y319.304 E16.5885
G92 E0
G1 E-0.6000 F3600
G1 Z1.850 F275
; layer 2, Z = 1.2
M106 S255
; outer perimeter
G1 Z1.350 F275
G1 E0.1500 F3600
G92 E0
G1 X337.100 Y300.400 E16.2882 F800
G92 E0
G1 E-0.6000 F3600
G1 Z1.850 F275
; solid layer
G1 Z1.350 F275
G1 E0.1500 F3600
G92 E0
G1 X336.596 Y300.904 E16.0669 F700
G92 E0
G1 E-0.6000 F3600
G1 Z1.850 F275
G1 Z1.350 F275
G1 E0.1500 F3600
G92 E0
G1 X335.796 Y301.704 E15.7157 F700
G92 E0
G1 E-0.6000 F3600
G1 Z1.850 F275
G1 Z1.350 F275
G1 E0.1500 F3600
G92 E0
G1 X334.996 Y302.504 E15.3644 F700
G92 E0
G1 E-0.6000 F3600
G1 Z1.850 F275
G1 Z1.350 F275
G1 E0.1500 F3600
G92 E0
G1 X334.196 Y303.304 E15.0132 F700
G92 E0
G1 E-0.6000 F3600
G1 Z1.850 F275
G1 Z1.350 F275
G1 E0.1500 F3600
G92 E0
G1 X333.396 Y304.104 E14.6620 F700
G92 E0
G1 E-0.6000 F3600
G1 Z1.850 F275
G1 Z1.350 F275
G1 E0.1500 F3600
G92 E0
G1 X332.596 Y304.904 E14.3107 F700
G92 E0
G1 E-0.6000 F3600
G1 Z1.850 F275
G1 Z1.350 F275
G1 E0.1500 F3600
G92 E0
G1 X331.796 Y305.704 E13.9595 F700
G92 E0
G1 E-0.6000 F3600
G1 Z1.850 F275
G1 Z1.350 F275
G1 E0.1500 F3600
G92 E0
G1 X330.996 Y306.504 E13.6083 F700
G92 E0
G1 E-0.6000 F3600
G1 Z1.850 F275
G1 Z1.350 F275
G1 E0.1500 F3600
G92 E0
G1 X330.196 Y307.304 E13.2571 F700
G92 E0
G1 E-0.6000 F3600
G1 Z1.850 F275
G1 Z1.350 F275
G1 E0.1500 F3600
G92 E0
G1 X329.396 Y308.104 E12.9058 F700
G92 E0
G1 E-0.6000 F3600
G1 Z1.850 F275
G1 Z1.350 F275
G1 E0.1500 F3600
G92 E0
G1 X328.596 Y308.904 E12.5546 F700
G92 E0
G1 E-0.6000 F3600
G1 Z1.850 F275
G1 Z1.350 F275
G1 E0.1500 F3600
G92 E0
G1 X327.796 Y309.704 E12.2034 F700
G92 E0
G1 E-0.6000 F3600
G1 Z1.850 F275
G1 Z1.350 F275
G1 E0.1500 F3600
G92 E0
G1 X326.996 Y310.504 E11.8522 F700
G92 E0
G1 E-0.6000 F3600
G1 Z1.850 F275
G1 Z1.350 F275
G1 E0.1500 F3600
G92 E0
G1 X326.196 Y311.304 E11.5009 F700
G92 E0
G1 E-0.6000 F3600
G1 Z1.850 F275
G1 Z1.350 F275
G1 E0.1500 F3600
G92 E0
G1 X325.396 Y312.104 E11.1497 F700
G92 E0
G1 E-0.6000 F3600
G1 Z1.850 F275
G1 Z1.350 F275
G1 E0.1500 F3600
G92 E0
G1 X324.596 Y312.904 E10.7985 F700
G92 E0
G1 E-0.6000 F3600
G1 Z1.850 F275
G1 Z1.350 F275
G1 E0.1500 F3600
G92 E0
G1 X323.796 Y313.704 E10.4472 F700
G92 E0
G1 E-0.6000 F3600
G1 Z1.850 F275
G1 Z1.350 F275
G1 E0.1500 F3600
G92 E0
G1 X322.996 Y314.504 E10.0960 F700
G92 E0
G1 E-0.6000 F3600
G1 Z1.850 F275
G1 Z1.350 F275
G1 E0.1500 F3600
G92 E0
G1 X322.196 Y315.304 E9.7448 F700
G92 E0
G1 E-0.6000 F3600
G1 Z1.850 F275
G1 Z1.350 F275
G1 E0.1500 F3600
G92 E0
G1 X321.396 Y316.104 E9.3936 F700
G92 E0
G1 E-0.6000 F3600
G1 Z1.850 F275
G1 Z1.350 F275
G1 E0.1500 F3600
G92 E0
G1 X320.596 Y316.904 E9.0423 F700
G92 E0
G1 E-0.6000 F3600
G1 Z1.850 F275
G1 Z1.350 F275
G1 E0.1500 F3600
G92 E0
G1 X319.796 Y317.704 E8.6911 F700
G92 E0
G1 E-0.6000 F3600
G1 Z1.850 F275
G1 Z1.350 F275
G1 E0.1500 F3600
G92 E0
G1 X318.996 Y318.504 E8.3399 F700
G92 E0
G1 E-0.6000 F3600
G1 Z1.850 F275
G1 Z1.350 F275
G1 E0.1500 F3600
G92 E0
G1 X318.196 Y319.304 E7.9887 F700
G92 E0
G1 E-0.6000 F3600
G1 Z2.450 F275
; layer 3, Z = 1.8
; outer perimeter
G1 Z1.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z2.450 F275
; tool H0.600 W0.880
; infill
G1 X271.190 Y339.056 F9000
G1 Z1.950 F275
G1 E0.1500 F3600
G92 E0
G1 X263.444 Y331.310 E2.6453 F1000
G1 X263.444 Y321.737 E4.9569
G1 X280.763 Y339.056 E10.8713
G1 X290.337 Y339.056 E13.1829
G1 X263.444 Y312.163 E22.3664
G1 X263.444 Y302.590 E24.6780
G1 X299.910 Y339.056 E37.1306
G1 X309.483 Y339.056 E39.4422
G1 X271.371 Y300.944 E52.4570
G1 X280.944 Y300.944 E54.7687
G1 X319.056 Y339.056 E67.7835
G1 X328.629 Y339.056 E70.0951
G1 X290.517 Y300.944 E83.1099
G1 X300.090 Y300.944 E85.4215
G1 X336.556 Y337.410 E97.8741
G1 X336.556 Y327.837 E100.1857
G1 X309.663 Y300.944 E109.3692
G1 X319.237 Y300.944 E111.6808
G1 X336.556 Y318.263 E117.5952
G1 X336.556 Y308.690 E119.9068
G1 X328.810 Y300.944 E122.5521
G92 E0
G1 E-0.6000 F3600
G1 Z3.050 F275
; layer 4, Z = 2.4
; outer perimeter
G1 Z2.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z3.050 F275
; infill
G1 X263.444 Y308.690 F9000
G1 Z2.550 F275
G1 E0.1500 F3600
G92 E0
G1 X271.190 Y300.944 E2.6453 F1000
G1 X280.763 Y300.944 E4.9569
G1 X263.444 Y318.263 E10.8713
G1 X263.444 Y327.837 E13.1829
G1 X290.337 Y300.944 E22.3664
G1 X299.910 Y300.944 E24.6780
G1 X263.444 Y337.410 E37.1306
G1 X263.444 Y339.056 E37.5282
G1 X271.371 Y339.056 E39.4423
G1 X309.483 Y300.944 E52.4570
G1 X319.056 Y300.944 E54.7687
G1 X280.944 Y339.056 E67.7835
G1 X290.517 Y339.056 E70.0951
G1 X328.629 Y300.944 E83.1099
G1 X336.556 Y300.944 E85.0239
G1 X336.556 Y302.590 E85.4215
G1 X300.090 Y339.056 E97.8741
G1 X309.663 Y339.056 E100.1857
G1 X336.556 Y312.163 E109.3692
G1 X336.556 Y321.737 E111.6808
G1 X319.237 Y339.056 E117.5952
G1 X328.810 Y339.056 E119.9068
G1 X336.556 Y331.310 E122.5521
G92 E0
G1 E-0.6000 F3600
G1 Z3.650 F275
; layer 5, Z = 3
; outer perimeter
G1 Z3.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z3.650 F275
; infill
G1 Z3.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z4.250 F275
; layer 6, Z = 3.6
; outer perimeter
G1 Z3.750 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z4.250 F275
; infill
G1 Z3.750 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z4.850 F275
; layer 7, Z = 4.2
; outer perimeter
G1 Z4.350 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z4.850 F275
; infill
G1 Z4.350 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z5.450 F275
; layer 8, Z = 4.8
; outer perimeter
G1 Z4.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z5.450 F275
; infill
G1 Z4.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z6.050 F275
; layer 9, Z = 5.4
; outer perimeter
G1 Z5.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z6.050 F275
; infill
G1 Z5.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z6.650 F275
; layer 10, Z = 6
; outer perimeter
G1 Z6.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z6.650 F275
; infill
G1 Z6.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z7.250 F275
; layer 11, Z = 6.6
; outer perimeter
G1 Z6.750 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z7.250 F275
; infill
G1 Z6.750 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z7.850 F275
; layer 12, Z = 7.2
; outer perimeter
G1 Z7.350 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z7.850 F275
; infill
G1 Z7.350 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z8.450 F275
; layer 13, Z = 7.8
; outer perimeter
G1 Z7.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z8.450 F275
; infill
G1 Z7.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z9.050 F275
; layer 14, Z = 8.4
; outer perimeter
G1 Z8.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z9.050 F275
; infill
G1 Z8.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z9.650 F275
; layer 15, Z = 9
; outer perimeter
G1 Z9.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z9.650 F275
; infill
G1 Z9.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z10.250 F275
; layer 16, Z = 9.6
; outer perimeter
G1 Z9.750 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z10.250 F275
; infill
G1 Z9.750 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z10.850 F275
; layer 17, Z = 10.2
; outer perimeter
G1 Z10.350 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z10.850 F275
; infill
G1 Z10.350 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z11.450 F275
; layer 18, Z = 10.8
; outer perimeter
G1 Z10.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z11.450 F275
; infill
G1 Z10.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z12.050 F275
; layer 19, Z = 11.4
; outer perimeter
G1 Z11.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z12.050 F275
; infill
G1 Z11.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z12.650 F275
; layer 20, Z = 12
; outer perimeter
G1 Z12.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z12.650 F275
; infill
G1 Z12.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z13.250 F275
; layer 21, Z = 12.6
; outer perimeter
G1 Z12.750 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z13.250 F275
; infill
G1 Z12.750 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z13.850 F275
; layer 22, Z = 13.2
; outer perimeter
G1 Z13.350 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z13.850 F275
; infill
G1 Z13.350 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z14.450 F275
; layer 23, Z = 13.8
; outer perimeter
G1 Z13.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z14.450 F275
; infill
G1 Z13.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z15.050 F275
; layer 24, Z = 14.4
; outer perimeter
G1 Z14.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z15.050 F275
; infill
G1 Z14.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z15.650 F275
; layer 25, Z = 15
; outer perimeter
G1 Z15.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z15.650 F275
; infill
G1 Z15.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z16.250 F275
; layer 26, Z = 15.6
; outer perimeter
G1 Z15.750 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z16.250 F275
; infill
G1 Z15.750 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z16.850 F275
; layer 27, Z = 16.2
; outer perimeter
G1 Z16.350 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z16.850 F275
; infill
G1 Z16.350 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z17.450 F275
; layer 28, Z = 16.8
; outer perimeter
G1 Z16.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z17.450 F275
; infill
G1 Z16.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z18.050 F275
; layer 29, Z = 17.4
; outer perimeter
G1 Z17.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z18.050 F275
; infill
G1 Z17.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z18.650 F275
; layer 30, Z = 18
; outer perimeter
G1 Z18.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z18.650 F275
; infill
G1 Z18.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z19.250 F275
; layer 31, Z = 18.6
; outer perimeter
G1 Z18.750 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z19.250 F275
; infill
G1 Z18.750 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z19.850 F275
; layer 32, Z = 19.2
; outer perimeter
G1 Z19.350 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z19.850 F275
; infill
G1 Z19.350 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z20.450 F275
; layer 33, Z = 19.8
; outer perimeter
G1 Z19.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z20.450 F275
; infill
G1 Z19.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z21.050 F275
; layer 34, Z = 20.4
; outer perimeter
G1 Z20.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z21.050 F275
; infill
G1 Z20.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z21.650 F275
; layer 35, Z = 21
; outer perimeter
G1 Z21.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z21.650 F275
; infill
G1 Z21.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z22.250 F275
; layer 36, Z = 21.6
; outer perimeter
G1 Z21.750 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z22.250 F275
; infill
G1 Z21.750 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z22.850 F275
; layer 37, Z = 22.2
; outer perimeter
G1 Z22.350 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z22.850 F275
; infill
G1 Z22.350 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z23.450 F275
; layer 38, Z = 22.8
; outer perimeter
G1 Z22.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z23.450 F275
; infill
G1 Z22.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z24.050 F275
; layer 39, Z = 23.4
; outer perimeter
G1 Z23.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z24.050 F275
; infill
G1 Z23.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z24.650 F275
; layer 40, Z = 24
; outer perimeter
G1 Z24.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z24.650 F275
; infill
G1 Z24.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z25.250 F275
; layer 41, Z = 24.6
; outer perimeter
G1 Z24.750 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z25.250 F275
; infill
G1 Z24.750 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z25.850 F275
; layer 42, Z = 25.2
; outer perimeter
G1 Z25.350 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z25.850 F275
; infill
G1 Z25.350 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z26.450 F275
; layer 43, Z = 25.8
; outer perimeter
G1 Z25.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z26.450 F275
; infill
G1 Z25.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z27.050 F275
; layer 44, Z = 26.4
; outer perimeter
G1 Z26.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z27.050 F275
; infill
G1 Z26.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z27.650 F275
; layer 45, Z = 27
; outer perimeter
G1 Z27.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z27.650 F275
; infill
G1 Z27.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z28.250 F275
; layer 46, Z = 27.6
; outer perimeter
G1 Z27.750 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z28.250 F275
; infill
G1 Z27.750 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z28.850 F275
; layer 47, Z = 28.2
; outer perimeter
G1 Z28.350 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z28.850 F275
; infill
G1 Z28.350 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z29.450 F275
; layer 48, Z = 28.8
; outer perimeter
G1 Z28.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z29.450 F275
; solid layer
G1 Z28.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z29.450 F275
G1 Z28.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z29.450 F275
G1 Z28.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z29.450 F275
G1 Z28.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z29.450 F275
G1 Z28.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z29.450 F275
G1 Z28.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z29.450 F275
G1 Z28.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z29.450 F275
G1 Z28.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z29.450 F275
G1 Z28.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z29.450 F275
G1 Z28.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z29.450 F275
G1 Z28.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z29.450 F275
G1 Z28.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z29.450 F275
G1 Z28.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z29.450 F275
G1 Z28.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z29.450 F275
G1 Z28.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z29.450 F275
G1 Z28.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z29.450 F275
G1 Z28.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z29.450 F275
G1 Z28.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z29.450 F275
G1 Z28.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z29.450 F275
G1 Z28.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z29.450 F275
G1 Z28.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z29.450 F275
G1 Z28.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z29.450 F275
G1 Z28.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z29.450 F275
G1 Z28.950 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.050 F275
; layer 49, Z = 29.4
; outer perimeter
G1 Z29.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.050 F275
; solid layer
G1 Z29.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.050 F275
G1 Z29.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.050 F275
G1 Z29.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.050 F275
G1 Z29.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.050 F275
G1 Z29.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.050 F275
G1 Z29.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.050 F275
G1 Z29.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.050 F275
G1 Z29.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.050 F275
G1 Z29.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.050 F275
G1 Z29.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.050 F275
G1 Z29.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.050 F275
G1 Z29.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.050 F275
G1 Z29.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.050 F275
G1 Z29.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.050 F275
G1 Z29.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.050 F275
G1 Z29.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.050 F275
G1 Z29.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.050 F275
G1 Z29.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.050 F275
G1 Z29.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.050 F275
G1 Z29.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.050 F275
G1 Z29.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.050 F275
G1 Z29.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.050 F275
G1 Z29.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.050 F275
G1 Z29.550 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.650 F275
; layer 50, Z = 30
; outer perimeter
G1 Z30.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.650 F275
; solid layer
G1 Z30.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.650 F275
G1 Z30.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.650 F275
G1 Z30.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.650 F275
G1 Z30.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.650 F275
G1 Z30.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.650 F275
G1 Z30.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.650 F275
G1 Z30.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.650 F275
G1 Z30.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.650 F275
G1 Z30.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.650 F275
G1 Z30.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.650 F275
G1 Z30.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.650 F275
G1 Z30.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.650 F275
G1 Z30.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.650 F275
G1 Z30.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.650 F275
G1 Z30.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.650 F275
G1 Z30.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.650 F275
G1 Z30.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.650 F275
G1 Z30.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.650 F275
G1 Z30.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.650 F275
G1 Z30.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.650 F275
G1 Z30.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.650 F275
G1 Z30.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.650 F275
G1 Z30.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
G1 Z30.650 F275
G1 Z30.150 F275
G1 E0.1500 F3600
G92 E0
G92 E0
G1 E-0.6000 F3600
; layer end
M190 S0
G28 X0 Y0
M18;
G4 P180000
M107
; Build Summary
;   Build time: 1 hour 11 minutes
;   Filament length: 12031.5 mm (12.03 m)
;   Plastic volume: 28939.26 mm^3 (28.94 cc)
;   Plastic weight: 36.17 g (0.08 lb)
;   Material cost: 1.09
Config file
# Robot module configurations : general handling of movement G-codes and slicing into moves
default_feed_rate                            4000             # Default rate ( mm/minute ) for G1/G2/G3 moves
default_seek_rate                            4000             # Default rate ( mm/minute ) for G0 moves
mm_per_arc_segment                           0.5              # Arcs are cut into segments ( lines ), this is the length for these segments.  Smaller values mean more resolution, higher values mean faster computation
#mm_per_line_segment                          5                # Lines can be cut into segments ( not usefull with cartesian coordinates robots ).
Arm solution configuration : Cartesian robot. Translates mm positions into stepper positions
alpha_steps_per_mm 118.52 # based on 1/32 microstepping Steps per mm for alpha stepper
beta_steps_per_mm 118.52 # based on 1/32 microstepping Steps per mm for beta stepper
gamma_steps_per_mm 4031.5 # based on 1/32 microstepping Steps per mm for gamma stepper
Planner module configuration : Look-ahead and acceleration configuration
planner_queue_size 32 # DO NOT CHANGE THIS UNLESS YOU KNOW EXACTLY WHAT YOUR ARE DOING
acceleration 700 # HAD 700 FOR AWHILE NOW LETS TRY 3001500 ORIGINALAcceleration in mm/second/second.
#z_acceleration 500 # Acceleration for Z only moves in mm/s^2, 0 disables it, disabled by default. DO NOT SET ON A DELTA
junction_deviation 0.05 # cahgned from 0.0375 Similar to the old “max_jerk”, in millimeters, see
Stepper module configuration
microseconds_per_step_pulse 1 # Duration of step pulses to stepper drivers, in microseconds
base_stepping_frequency 100000 # Base frequency for stepping
Stepper module pins ( ports, and pin numbers, appending “!” to the number will invert a pin )
alpha_step_pin 2.1 # Pin for alpha stepper step signal
alpha_dir_pin 0.11 # Pin for alpha stepper direction
alpha_en_pin 0.10 # Pin for alpha enable pin
alpha_current 0.9 # X stepper motor current
x_axis_max_speed 9000 # mm/min
alpha_max_rate 9000 # mm/min actuator max speed
beta_step_pin 2.2 # Pin for beta stepper step signal
beta_dir_pin 0.20 # Pin for beta stepper direction
beta_en_pin 0.19 # Pin for beta enable
beta_current 1.8 # Y stepper motor current
y_axis_max_speed 9000 # mm/min
beta_max_rate 9000 # mm/min actuator max speed
gamma_step_pin 2.3 # Pin for gamma stepper step signal
gamma_dir_pin 0.22! # Pin for gamma stepper direction
gamma_en_pin 0.21 # Pin for gamma enable
gamma_current 1.8 # Z stepper motor current
z_axis_max_speed 300 # mm/min
gamma_max_rate 300.0 # mm/min actuator max speed
Serial communications configuration ( baud rate default to 9600 if undefined )
uart0.baud_rate 115200 # Baud rate for the default hardware serial port
second_usb_serial_enable false # This enables a second usb serial port (to have both pronterface and a terminal connected)
#msd_disable false # disable the MSD (USB SDCARD) when set to true
#leds_disable true # disable using leds after config loaded
#dfu_enable false # for linux developers, set to true to enable DFU
#watchdog_timeout 10 # watchdog timeout in seconds, default is 10, set to 0 to disable the watchdog
Extruder module configuration
extruder.hotend.enable true # Whether to activate the extruder module at all. All configuration is ignored if false
extruder.hotend.steps_per_mm 810.75 # Steps per mm for extruder stepper
extruder.hotend.default_feed_rate 600 # Default rate ( mm/minute ) for moves where only the extruder moves
extruder.hotend.acceleration 500 # Acceleration for the stepper motor mm/sec²
extruder.hotend.max_speed 100 # PREVIOUSLY WAS 50 mm/s
extruder.hotend.step_pin 2.0 # Pin for extruder step signal
extruder.hotend.dir_pin 0.5 # Pin for extruder dir signal
extruder.hotend.en_pin 0.4 # Pin for extruder enable signal
delta_current 1.0 # Extruder stepper motor current
Laser module configuration
laser_module_enable false # Whether to activate the laser module at all. All configuration is
# ignored if false.
#laser_module_pin 2.5 # this pin will be PWMed to control the laser. Only P2.0 - P2.5, P1.18, P1.20, P1.21, P1.23, P1.24, P1.26, P3.25, P3.26
# can be used since laser requires hardware PWM
#laser_module_maximum_power 1.0 # this is the maximum duty cycle that will be applied to the laser
#laser_module_minimum_power 0.0 # This is a value just below the minimum duty cycle that keeps the laser
# active without actually burning.
#laser_module_default_power 0.8 # This is the default laser power that will be used for cuts if a power has not been specified. The value is a scale between
# the maximum and minimum power levels specified above
#laser_module_pwm_period 20 # this sets the pwm frequency as the period in microseconds
Hotend temperature control configuration
temperature_control.hotend.enable true # Whether to activate this ( “hotend” ) module at all. All configuration is ignored if false.
temperature_control.hotend.thermistor_pin 0.24 # Pin for the thermistor to read
temperature_control.hotend.heater_pin 2.5 # Pin that controls the heater
temperature_control.hotend.thermistor Semitec # see
#temperature_control.hotend.beta 4066 # or set the beta value
temperature_control.hotend.i_max 128 #added in myself to help wiht 3 degree bounce
temperature_control.hotend.designator T #
temperature_control.hotend.max_temp 290 # Set maximum temperature - Will prevent heating above 300 by default
#temperature_control.hotend.min_temp 0 # Set minimum temperature - Will prevent heating below 0 by default
temperature_control.hotend.p_factor 41.0 #8/2/2016 at 210 was run
temperature_control.hotend.i_factor 2.615 #
temperature_control.hotend.d_factor 161 #
temperature_control.bed.enable false #
temperature_control.bed.thermistor_pin 0.23 #
temperature_control.bed.heater_pin 2.7 #
temperature_control.bed.thermistor EPCOS100K # see
#temperature_control.bed.beta 4066 # or set the beta value
#temperature_control.hotend.rt_curve 19.0,98700,180,1120,235,460 #this is ther thermistor that i have in house
temperature_control.bed.set_m_code 140 #
temperature_control.bed.set_and_wait_m_code 190 #
temperature_control.bed.designator B #
Switch module for fan control
switch.fan.enable true #
switch.fan.input_on_command M106 #
switch.fan.input_off_command M107 #
switch.fan.output_pin 1.25 #
switch.misc.enable false #
switch.misc.input_on_command M42 #
switch.misc.input_off_command M43 #
switch.misc.output_pin 0.26 #
automatically toggle a switch at a specified temperature. Different ones of these may be defined to monitor different temperatures and switch different swithxes
useful to turn on a fan or water pump to cool the hotend
#temperatureswitch.hotend.enable true #
#temperatureswitch.hotend.designator T # first character of the temperature control designator to use as the temperature sensor to monitor
#temperatureswitch.hotend.switch misc # select which switch to use, matches the name of the defined switch
#temperatureswitch.hotend.threshold_temp 60.0 # temperature to turn on (if rising) or off the switch
#temperatureswitch.hotend.heatup_poll 15 # poll heatup at 15 sec intervals
#temperatureswitch.hotend.cooldown_poll 60 # poll cooldown at 60 sec intervals
filament out detector
#filament_detector.enable true #
#filament_detector.encoder_pin 0.26 # must be interrupt enabled pin (0.26, 0.27, 0.28)
#filament_detector.seconds_per_check 2 # may need to be longer
#filament_detector.pulses_per_mm 1 .0 # will need to be tuned
#filament_detector.bulge_pin 0.27 # optional bulge detector switch and/or manual suspend
Switch module for spindle control
#switch.spindle.enable false #
Endstops
endstops_enable true # the endstop module is enabled by default and can be disabled here
#corexy_homing false # set to true if homing on a hbit or corexy
alpha_min_endstop 1.24^! # add a ! to invert if endstop is NO connected to ground
#alpha_max_endstop 1.24^! #
alpha_homing_direction home_to_min # or set to home_to_max and set alpha_max
alpha_min 0 # this gets loaded after homing when home_to_min is set
alpha_max 600 # this gets loaded after homing when home_to_max is set
#beta_min_endstop 1.26^! #
beta_max_endstop 1.26^! #
beta_homing_direction home_to_max #
beta_min 0 #
beta_max 600 #
gamma_min_endstop 1.28^! #
#gamma_max_endstop 1.28^! #
gamma_homing_direction home_to_min #
gamma_min 0 #
gamma_max 600 #
alpha_max_travel 600 # max travel in mm for alpha/X axis when homing
beta_max_travel 600 # max travel in mm for beta/Y axis when homing
gamma_max_travel 600 # max travel in mm for gamma/Z axis when homing
optional enable limit switches, actions will stop if any enabled limit switch is triggered
#alpha_limit_enable true # set to true to enable X min and max limit switches
#beta_limit_enable true # set to true to enable Y min and max limit switches
#gamma_limit_enable true # set to true to enable Z min and max limit switches
#move_to_origin_after_home false # move XY to 0,0 after homing
#probe endstop
#probe_pin 1.29 # optional pin for probe
alpha_fast_homing_rate_mm_s 50 # feedrates in mm/second
beta_fast_homing_rate_mm_s 50 # "
gamma_fast_homing_rate_mm_s 4 # "
alpha_slow_homing_rate_mm_s 25 # "
beta_slow_homing_rate_mm_s 25 # "
gamma_slow_homing_rate_mm_s 2 # "
alpha_homing_retract_mm 5 # distance in mm
beta_homing_retract_mm 5 # "
gamma_homing_retract_mm 1 # "
#endstop_debounce_count 100 # uncomment if you get noise on your endstops, default is 100
optional Z probe
zprobe.enable false # set to true to enable a zprobe
zprobe.probe_pin 1.29!^ # pin probe is attached to if NC remove the !
zprobe.slow_feedrate 5 # mm/sec probe feed rate
#zprobe.debounce_count 100 # set if noisy
zprobe.fast_feedrate 100 # move feedrate mm/sec
zprobe.probe_height 5 # how much above bed to start probe
associated with zprobe the leveling strategy to use
#leveling-strategy.three-point-leveling.enable true # a leveling strategy that probes three points to define a plane and keeps the Z parallel to that plane
#leveling-strategy.three-point-leveling.point1 100.0,0.0 # the first probe point (x,y) optional may be defined with M557
#leveling-strategy.three-point-leveling.point2 200.0,200.0 # the second probe point (x,y)
#leveling-strategy.three-point-leveling.point3 0.0,200.0 # the third probe point (x,y)
#leveling-strategy.three-point-leveling.home_first true # home the XY axis before probing
#leveling-strategy.three-point-leveling.tolerance 0.03 # the probe tolerance in mm, anything less that this will be ignored, default is 0.03mm
#leveling-strategy.three-point-leveling.probe_offsets 0,0,0 # the probe offsets from nozzle, must be x,y,z, default is no offset
#leveling-strategy.three-point-leveling.save_plane false # set to true to allow the bed plane to be saved with M500 default is false
kill button (used to be called pause) maybe assigned to a different pin, set to the onboard pin by default
kill_button_enable true # set to true to enable a kill button
kill_button_pin 2.12 # kill button pin. default is same as pause button 2.12 (2.11 is another good choice)
Panel See
panel.enable false # set to true to enable the panel code
Example viki2 config for an azteeg mini V2 with IDC cable
panel.lcd viki2 # set type of panel
panel.spi_channel 0 # set spi channel to use P0_18,P0_15 MOSI,SCLK
panel.spi_cs_pin 0.16 # set spi chip select
panel.encoder_a_pin 3.25!^ # encoder pin
panel.encoder_b_pin 3.26!^ # encoder pin
panel.click_button_pin 2.11!^ # click button
panel.a0_pin 2.6 # st7565 needs an a0
panel.contrast 8 # override contrast setting (default is 9) miniViki (4 or lower)
#panel.encoder_resolution 4 # override number of clicks to move 1 item (default is 4)
#panel.button_pause_pin 1.30^ # kill/pause set one of these for the auxilliary button on viki2
#panel.back_button_pin 1.30!^ # back button recommended to use this on EXP1
panel.buzz_pin 0.25 # pin for buzzer on EXP2
panel.red_led_pin 2.8 # pin for red led on viki2 on EXP1
panel.blue_led_pin 4.29 # pin for blue led on viki2 on EXP1
panel.external_sd true # set to true if there is an extrernal sdcard on the panel
panel.external_sd.spi_channel 0 # set spi channel the sdcard is on
panel.external_sd.spi_cs_pin 1.23 # set spi chip select for the sdcard
panel.external_sd.sdcd_pin 1.31!^ # sd detect signal (set to nc if no sdcard detect)
panel.menu_offset 1 # some panels will need 1 here
panel.gamma_jog_feedrate 200 # z jogging feedrate in mm/min
panel.hotend_temperature 185 # temp to set hotend when preheat is selected
panel.bed_temperature 60 # temp to set bed when preheat is selected
Example of a custom menu entry, which will show up in the Custom entry.
NOTE _ gets converted to space in the menu and commands, | is used to separate multiple commands
custom_menu.power_on.name Power_on #
custom_menu.power_on.command M80 #
custom_menu.power_off.enable true #
custom_menu.power_off.name Power_off #
custom_menu.power_off.command M81 #
network settings
network.enable true # enable the ethernet network services
network.webserver.enable true # enable the webserver
network.telnet.enable true # enable the telnet server
network.plan9.enable true # enable the plan9 network filesystem
network.ip_address // # the IP address
#network.ip_mask 255.255.255.0 # the ip mask
#network.ip_gateway // # the gateway address
Azteeg specific settings do not change
currentcontrol_module_enable true #
digipot_max_current 2.0 # max current
digipot_factor 113.5 # factor for converting current to digipot value
Any thoughts on what the issue could be would be very much appreciated.
