Hey guys! I just got and installed my Azteeg x5 Mini V3 today!
I’ve got motion and extruder 1 all working via Repetier but I’m having several issues.
The Setup:
Openbeam Kossel Pro w/ Azteeg x5 Mini V3 and a Poly Stroooder Tri-Hotend (3 nozzles/extruder motors) and a Printrbot Extrudrboard to run the additional heads and the latest version of Smoothieware.
I’m using Repetier Host and Slic3r (latest versions of everything)
running windows 7 and editing the config files with gedit as recommended in the smoothie documentation (by the way the documentation is beautiful and fairly comprehensive! good job guys)
I’m having a series of problems so I’ll list them out here:
When I go to print with extruder 1 (assume the others are not even setup in the config yet) the machine heats up and executes the bed probe sequence. after that the head moves to the center (~35mm above the surface) then it moves a little bit, maybe 2 line segments, then it just freezes up. the temperatures are no longer updated and nothing happens. I have to power cycle the machine to talk to it again. I’ve been making sure to ‘eject’ my sd card in windows when connected to the machine. I also reconfigured Repetier to a single extruder for this machine and the problem still occurs.
I can setup two hotend modules in the config but as soon as I add the third, smoothie will not boot/none of the 4 LEDs will illuminate. If I set extruder.hotend2.enable to false it will ignore the 3rd hotend and load up no problem. (modules are hotend 0, hotend1, and hotend2) Howcome i cannot configure it for 3 hotends?
I see ‘delta_current’ and ‘epsilon_current’ as options in the Extruder configuration documentation and I assume its for the digipots. Just to be clear, I wouldn’t use ‘epsilon_current’ with additional extruders because the extrudrboard does not have digipots, right? So it should be okay to omit?
After reviewing the datasheet I’ve found that P0.30 and P0.31 in the EXP1 header are ADC inputs so I’ve selected them as the inputs for the additional hotend thermistors. However, with the thermistors plugged into the Extrudrboard and the Extrudrboard plugged into EXP2 and EXP1(just the thermistors on EXP1) both are reported as 0.0c in Repetier. I’ve tried other analog inputs and none seem to work. to rule out the thermistors being bad I plugged them into the heated bed input and they report the correct temperature. I also plugged the heated bed into those ports and got 0.0c. All my thermistors are the same (semitec) I do not understand why these analog inputs are not working.
I am using a config file provided to me by MatterHackers, they have a very similar machine so I just modified their config to suit my machine. Here is my modified version.
[[code]]# Robot module configurations : general handling of movement G-codes and slicing into moves
arm_solution linear_delta # delta selection
arm_length 300.00 # this is the length of an arm from hinge to hinge
arm_radius 152.357 # this is the horizontal distance from hinge to hinge when the effector is centered
default_feed_rate 4000 # Default rate ( mm/minute ) for G1/G2/G3 moves
default_seek_rate 4000 # Default rate ( mm/minute ) for G0 moves
mm_per_arc_segment 0.0 # Fixed length for line segments that divide arcs 0 to disable
mm_max_arc_error 0.01 # The maximum error for line segments that divide arcs 0 to disable
# note it is invalid for both the above be 0
# if both are used, will use largest segment length based on radius
#mm_per_line_segment 5 # Lines can be cut into segments ( not usefull with cartesian coordinates robots ).
delta_segments_per_second 100 # segments per second used for deltas
- Arm solution configuration : Cartesian robot. Translates mm positions into stepper positions
- 1/128 Microstepping
#alpha_steps_per_mm 640 # Steps per mm for alpha stepper
#beta_steps_per_mm 640 # Steps per mm for beta stepper
#gamma_steps_per_mm 640 # Steps per mm for gamma stepper
- 1/32 Microstepping
alpha_steps_per_mm 160 # Steps per mm for alpha stepper
beta_steps_per_mm 160 # Steps per mm for beta stepper
gamma_steps_per_mm 160 # Steps per mm for gamma stepper
- 1/16 Microstepping
#alpha_steps_per_mm 80 # Steps per mm for alpha stepper
#beta_steps_per_mm 80 # Steps per mm for beta stepper
#gamma_steps_per_mm 80 # Steps per mm for gamma stepper
- Planner module configuration : Look-ahead and acceleration configuration
planner_queue_size 32 # DO NOT CHANGE THIS UNLESS YOU KNOW EXACTLY WHAT YOUR ARE DOING
acceleration 2000 # Acceleration in mm/second/second.
junction_deviation 0.05 # Similar to the old "max_jerk", in millimeters, see :
# and . Lower values mean being more careful, higher values means being faster and have more jerk
- Stepper module configuration
microseconds_per_step_pulse 1 # Duration of step pulses to stepper drivers, in microseconds
base_stepping_frequency 100000 # Base frequency for stepping
- Stepper module pins ( ports, and pin numbers, appending "!" to the number will invert a pin )
alpha_step_pin 2.1 # Pin for alpha stepper step signal
alpha_dir_pin 0.11 # Pin for alpha stepper direction
alpha_en_pin 0.10 # Pin for alpha enable pin
alpha_current 1.0 # X stepper motor current
alpha_max_rate 30000.0 # mm/min actuator max speed
x_axis_max_speed 30000.0 # mm/min cartesian max speed
beta_step_pin 2.2 # Pin for beta stepper step signal
beta_dir_pin 0.20 # Pin for beta stepper direction
beta_en_pin 0.19 # Pin for beta enable
beta_current 1.0 # Y stepper motor current
beta_max_rate 30000.0 # mm/min
y_axis_max_speed 30000.0 # mm/min
gamma_step_pin 2.3 # Pin for gamma stepper step signal
gamma_dir_pin 0.22 # Pin for gamma stepper direction
gamma_en_pin 0.21 # Pin for gamma enable
gamma_current 1.0 # Z stepper motor current
gamma_max_rate 30000.0 # mm/min
z_axis_max_speed 30000.0 # mm/min
- Serial communications configuration ( baud rate default to 9600 if undefined )
uart0.baud_rate 115200 # Baud rate for the default hardware serial port
second_usb_serial_enable false # This enables a second usb serial port (to have both pronterface and a terminal connected)
#msd_disable false # disable the MSD (USB SDCARD) when set to true
#leds_disable true # disable using leds after config loaded
#dfu_enable false # for linux developers, set to true to enable DFU
#watchdog_timeout 10 # watchdog timeout in seconds, default is 10, set to 0 to disable the watchdog
## Extruder module configuration
extruder.hotend0.enable true # Whether to activate the extruder module at all. All configuration is ignored if false
extruder.hotend0.steps_per_mm 184.8 # Steps per mm for extruder stepper
extruder.hotend0.default_feed_rate 600 # Default rate ( mm/minute ) for moves where only the extruder moves
extruder.hotend0.acceleration 500 # Acceleration for the stepper motor mm/sec²
extruder.hotend0.max_speed 50 # mm/s
extruder.hotend0.step_pin 2.0 # Pin for extruder step signal
extruder.hotend0.dir_pin 0.5 # Pin for extruder dir signal
extruder.hotend0.en_pin 0.4 # Pin for extruder enable signal
- extruder offset
extruder.hotend0.x_offset 0 # x offset from origin in mm
extruder.hotend0.y_offset -6.04 # y offset from origin in mm
extruder.hotend0.z_offset 0 # z offset from origin in mm
- firmware retract settings when using G10/G11, these are the defaults if not defined, must be defined for each extruder if not using the defaults
#extruder.hotend0.retract_length 3 # retract length in mm
#extruder.hotend0.retract_feedrate 45 # retract feedrate in mm/sec
#extruder.hotend0.retract_recover_length 0 # additional length for recover
#extruder.hotend0.retract_recover_feedrate 8 # recover feedrate in mm/sec (should be less than retract feedrate)
#extruder.hotend0.retract_zlift_length 0 # zlift on retract in mm, 0 disables
#extruder.hotend0.retract_zlift_feedrate 6000 # zlift feedrate in mm/min (Note mm/min NOT mm/sec)
extruder.hotend1.enable true # Whether to activate the extruder module at all. All configuration is ignored if false
extruder.hotend1.steps_per_mm 184.8 # Steps per mm for extruder stepper
extruder.hotend1.default_feed_rate 600 # Default rate ( mm/minute ) for moves where only the extruder moves
extruder.hotend1.acceleration 500 # Acceleration for the stepper motor mm/sec²
extruder.hotend1.max_speed 50 # mm/s
extruder.hotend1.step_pin 2.11 # Pin for extruder step signal
extruder.hotend1.dir_pin 1.23! # Pin for extruder dir signal
extruder.hotend1.en_pin 0.16 # Pin for extruder enable signal
- extruder offset
extruder.hotend1.x_offset -5.23 # x offset from origin in mm
extruder.hotend1.y_offset 3.02 # y offset from origin in mm
extruder.hotend1.z_offset 0 # z offset from origin in mm
delta_current 1.0 # Extruder stepper motor current
extruder.hotend2.enable false # Whether to activate the extruder module at all. All configuration is ignored if false
extruder.hotend2.steps_per_mm 184.8 # Steps per mm for extruder stepper
extruder.hotend2.default_feed_rate 600 # Default rate ( mm/minute ) for moves where only the extruder moves
extruder.hotend2.acceleration 500 # Acceleration for the stepper motor mm/sec²
extruder.hotend2.max_speed 50 # mm/s
extruder.hotend2.step_pin 3.25 # Pin for extruder step signal
extruder.hotend2.dir_pin 3.26! # Pin for extruder dir signal
extruder.hotend2.en_pin 2.6 # Pin for extruder enable signal
- extruder offset
extruder.hotend2.x_offset 5.23 # x offset from origin in mm
extruder.hotend2.y_offset 3.02 # y offset from origin in mm
extruder.hotend2.z_offset 0 # z offset from origin in mm
- Laser module configuration
laser_module_enable false # Whether to activate the laser module at all. All configuration is
# ignored if false.
#laser_module_pin 2.5 # this pin will be PWMed to control the laser. Only P2.0 - P2.5, P1.18, P1.20, P1.21, P1.23, P1.24, P1.26, P3.25, P3.26
# can be used since laser requires hardware PWM
#laser_module_maximum_power 1.0 # this is the maximum duty cycle that will be applied to the laser
#laser_module_minimum_power 0.0 # This is a value just below the minimum duty cycle that keeps the laser
# active without actually burning.
#laser_module_default_power 0.8 # This is the default laser power that will be used for cuts if a power has not been specified. The value is a scale between
# the maximum and minimum power levels specified above
#laser_module_pwm_period 20 # this sets the pwm frequency as the period in microseconds
- Hotend0 temperature control configuration
temperature_control.hotend0.enable true # Whether to activate this ( "hotend" ) module at all. All configuration is ignored if false.
temperature_control.hotend0.thermistor_pin 0.24 # Pin for the thermistor to read
temperature_control.hotend0.heater_pin 2.5 # Pin that controls the heater
temperature_control.hotend0.thermistor Semitec # see
#temperature_control.hotend0.beta 4066 # or set the beta value
temperature_control.hotend0.set_m_code 104 #
temperature_control.hotend0.set_and_wait_m_code 109 #
temperature_control.hotend0.designator T0 #
#temperature_control.hotend0.max_temp 340 # Set maximum temperature - Will prevent heating above 300 by default
#temperature_control.hotend0.min_temp 0 # Set minimum temperature - Will prevent heating below 0 by default
#P39.98 I5.00 D79.91
temperature_control.hotend0.p_factor 65.1 #
temperature_control.hotend0.i_factor 6.409 #
temperature_control.hotend0.d_factor 165 #
- Hotend1 temperature control configuration
temperature_control.hotend1.enable false # Whether to activate this ( "hotend" ) module at all. All configuration is ignored if false.
temperature_control.hotend1.thermistor_pin 1.31 # Pin for the thermistor to read
temperature_control.hotend1.heater_pin 0.15 # Pin that controls the heater
temperature_control.hotend1.thermistor Semitec # see
#temperature_control.hotend1.beta 4066 # or set the beta value
temperature_control.hotend1.set_m_code 104 #
temperature_control.hotend1.set_and_wait_m_code 109 #
temperature_control.hotend1.designator T1 #
#temperature_control.hotend1.max_temp 340 # Set maximum temperature - Will prevent heating above 300 by default
#temperature_control.hotend1.min_temp 0 # Set minimum temperature - Will prevent heating below 0 by default
temperature_control.hotend1.p_factor 65.1 #
temperature_control.hotend1.i_factor 6.409 #
temperature_control.hotend1.d_factor 165 #
- Hotend2 temperature control configuration
temperature_control.hotend2.enable false # Whether to activate this ( "hotend" ) module at all. All configuration is ignored if false.
temperature_control.hotend2.thermistor_pin 1.30 # Pin for the thermistor to read
temperature_control.hotend2.heater_pin 0.18 # Pin that controls the heater
temperature_control.hotend2.thermistor Semitec
#temperature_control.hotend2.beta 4066 # or set the beta value
temperature_control.hotend2.set_m_code 104 #
temperature_control.hotend2.set_and_wait_m_code 109 #
temperature_control.hotend2.designator T2 #
#temperature_control.hotend2.max_temp 340 # Set maximum temperature - Will prevent heating above 300 by default
#temperature_control.hotend2.min_temp 0 # Set minimum temperature - Will prevent heating below 0 by default
temperature_control.hotend2.p_factor 65.1 #
temperature_control.hotend2.i_factor 6.409 #
temperature_control.hotend2.d_factor 165 #
- For bed
temperature_control.bed.enable true #
temperature_control.bed.thermistor_pin 0.23 #
temperature_control.bed.heater_pin 2.7 #
temperature_control.bed.thermistor Semitec
#temperature_control.bed.beta 4066 # or set the beta value
temperature_control.bed.set_m_code 140 #
temperature_control.bed.set_and_wait_m_code 190 #
temperature_control.bed.designator B #
- uncomment followng to use bang bang isntead of PID for the bed (best for relay conrolled hotbeds)
#temperature_control.bed.bang_bang true # set to true to use bang bang control rather than PID
#temperature_control.bed.hysteresis 2.0 # set to the temperature in degrees C to use as hysteresis when using bang bang
- Switch module for fan control
switch.fan.enable true #
switch.fan.input_on_command M106 #
switch.fan.input_off_command M107 #
switch.fan.output_pin 2.4 #
- automatically toggle a switch at a specified temperature. Different ones of these may be defined to monitor different temperatures and switch different swithxes
- useful to turn on a fan or water pump to cool the hotend
#temperatureswitch.hotend.enable true #
#temperatureswitch.hotend.designator T # first character of the temperature control designator to use as the temperature sensor to monitor
#temperatureswitch.hotend.switch misc # select which switch to use, matches the name of the defined switch
#temperatureswitch.hotend.threshold_temp 60.0 # temperature to turn on (if rising) or off the switch
#temperatureswitch.hotend.heatup_poll 15 # poll heatup at 15 sec intervals
#temperatureswitch.hotend.cooldown_poll 60 # poll cooldown at 60 sec intervals
- switch.psu.enable true # turn atx on/off
- switch.psu.input_on_command M80 #
- switch.psu.input_off_command M81 #
- switch.psu.output_pin 2.13o! # open drain, inverted
- Switch module for spindle control
#switch.spindle.enable false #
- Endstops
endstops_enable true # the endstop module is enabled by default and can be disabled here
delta_homing true # forces all three axis to home a the same time regardless of what is specified in G28
alpha_max_endstop 1.24^ #
alpha_homing_direction home_to_max # or set to home_to_max and set alpha_max
alpha_min 0 # this gets loaded after homing when home_to_min is set
alpha_max 0 # this gets loaded after homing when home_to_max is set
beta_max_endstop 1.26^ #
beta_homing_direction home_to_max #
beta_min 0 #
beta_max 0 #
gamma_max_endstop 1.28^ #
gamma_homing_direction home_to_max #
gamma_min 0 #
gamma_max 245.1375 # change to suit your height
#probe endstop
#probe_pin 1.29 # optional pin for probe
alpha_fast_homing_rate_mm_s 200 # feedrates in mm/second
beta_fast_homing_rate_mm_s 200 # "
gamma_fast_homing_rate_mm_s 200 # "
alpha_slow_homing_rate_mm_s 20 # "
beta_slow_homing_rate_mm_s 20 # "
gamma_slow_homing_rate_mm_s 20 # "
alpha_homing_retract_mm 5 # distance in mm
beta_homing_retract_mm 5 # "
gamma_homing_retract_mm 5 # "
alpha_trim 0 # software trim for alpha stepper endstop (in mm) - moves down
beta_trim 0 # software trim for beta stepper endstop (in mm)
gamma_trim 0 # software trim for gamma stepper endstop (in mm)
- optional enable limit switches, actions will stop if any enabled limit switch is triggered
#alpha_limit_enable false # set to true to enable X min and max limit switches
#beta_limit_enable false # set to true to enable Y min and max limit switches
#gamma_limit_enable false # set to true to enable Z min and max limit switches
#move_to_origin_after_home true # move XY to 0,0 after homing
- optional Z probe
zprobe.enable true # set to true to enable a zprobe
zprobe.probe_pin 1.29!^ # pin probe is attached to if NC remove the !
zprobe.slow_feedrate 10 # mm/sec probe feed rate
#zprobe.debounce_count 100 # set if noisy
zprobe.fast_feedrate 100 # move feedrate
zprobe.probe_height 5 # how much above bed to start probe
- associated with zprobe the leveling strategy to use
leveling-strategy.delta-calibration.enable true # basic delta calibration
leveling-strategy.delta-calibration.radius 107 # the probe radius
- kill button (used to be called pause) maybe assigned to a different pin, set to the onboard pin by default
kill_button_enable true # set to true to enable a kill button
kill_button_pin 2.12 # kill button pin. default is same as pause button 2.12 (2.11 is another good choice)
- Panel See
panel.enable false # set to true to enable the panel code
- Example viki2 config for an azteeg miniV2 with IDC cable
panel.lcd viki2 # set type of panel
panel.spi_channel 0 # set spi channel to use P0_18,P0_15 MOSI,SCLK
panel.spi_cs_pin 0.16 # set spi chip select
panel.encoder_a_pin 3.25!^ # encoder pin
panel.encoder_b_pin 3.26!^ # encoder pin
panel.click_button_pin 2.11!^ # click button
panel.a0_pin 2.6 # st7565 needs an a0
#panel.contrast 8 # override contrast setting (default is 9)
#panel.encoder_resolution 4 # override number of clicks to move 1 item (default is 4)
#panel.button_pause_pin 1.30^ # kill/pause set one of these for the auxilliary button on viki2
#panel.back_button_pin 1.30!^ # back button recommended to use this on EXP1
panel.buzz_pin 0.25 # pin for buzzer on EXP2
panel.red_led_pin 2.8 # pin for red led on viki2 on EXP1
panel.blue_led_pin 4.29 # pin for blue led on viki2 on EXP1
panel.external_sd true # set to true if there is an extrernal sdcard on the panel
panel.external_sd.spi_channel 0 # set spi channel the sdcard is on
panel.external_sd.spi_cs_pin 1.23 # set spi chip select for the sdcard
panel.external_sd.sdcd_pin 1.31!^ # sd detect signal (set to nc if no sdcard detect)
panel.menu_offset 1 # some panels will need 1 here
- Example mini viki2 config
#panel.lcd mini_viki2 # set type of panel
#panel.spi_channel 0 # set spi channel to use P0_18,P0_15 MOSI,SCLK
#panel.spi_cs_pin 0.16 # set spi chip select
#panel.encoder_a_pin 3.25!^ # encoder pin
#panel.encoder_b_pin 3.26!^ # encoder pin
#panel.click_button_pin 2.11!^ # click button
#panel.a0_pin 2.6 # st7565 needs an a0
##panel.contrast 18 # override contrast setting (default is 18)
##panel.encoder_resolution 2 # override number of clicks to move 1 item (default is 2)
#panel.menu_offset 1 # here controls how sensitive the menu is. some panels will need 1
panel.gamma_jog_feedrate 200 # z jogging feedrate in mm/min
panel.hotend_temperature 185 # temp to set hotend when preheat is selected
panel.bed_temperature 60 # temp to set bed when preheat is selected
- Azteeg specific settings do not change
currentcontrol_module_enable true #
digipot_max_current 2.0 # max current
digipot_factor 106.0 # factor for converting current to digipot value[[/code]]
Thanks for the help, I can’t wait to get up and running on smoothie!
I’ve got two more machines to convert!
