@Printrbot - RevF4 board - with voltage selection and input buffering on the Z-stop.
How do I wire a mechanical homing switch for the Z axis?
[UPDATE: RTM https://printrbot.com/shop/printrboard-rev-f6/ specifically the pdf linked to by the words “Click here for instructions for connecting a Z end stop and full wiring diagrams.”]
The probe I received in my DIY kit doesn’t work. The LED comes on when near metal, but the signal line is always hot regardless of the state of the LED (or proximity to metal). Therefore I can’t home my printer.
Looking at the schematic, there’s some extra bits attached to Pin 1.
X&Y pull pin 1 low (to ground) when closed.
Can I wire the same with the Z port? (1 & 3 to a NC switch?) or 1 & 2? and do I need t change the voltage selector?
[UPDATE: Change voltage to 5V via jumper, wire pins 1 & 2 to a NO momentary switch]
