Probably get a better response here.
Probably get a better response here. :stuck_out_tongue:
Originally shared by ThantiK
Marlin Mainline Configuration.h states that Delta Kinematics are not yet compatible with their implementation of auto bed leveling – Anyone have a suggestion of a default branch I can check out? Do I still use @Johann_Rocholl 's branch? Is there some other, better, more developed branch that people are using?
#3dprinting #delta
/sub
hah, @Petr_Sedlacek I don’t think anyone knows any better than I do… :frowning:
@ThantiK ​ I’ve been using Repetier-Firmware with my Rostock. It does have auto-bed levelling, I just didn’t get around to installing a probe yet. I’m currently building an enlarged Kossel and I’ve got both inductive sensors and FSRs to try. I want to get a 32bit ARM board though which means I’ll probably end up with SmoothieWare. I like RAMPS-FD but nobody seems to make the latest revision and the firmware support is also poor. (Sorry for a bit of an OT :slight_smile:)
/sub
even though my late rant about the messy state of marlin makes me want to try a 32 bit arm board and fresh firmware also :s
Please tell us if you find a solution! Did you try Richard Horne 3DR branch? I did not check if it has auto leveling though.
