Probably the most literal knockoff I've seen of the Bukito.
Probably the most literal knockoff I’ve seen of the Bukito.
https://youtu.be/bNxBIM_SSto
I’m curious as to what they are using as a disposable print sheet on it ??? any ideas???
Looks like brown packaging tape…had somewhat decent results with most tape with a similar texture to blue painter’s but the board itself is not garolite so the tape is bound to peel off. You’d be fine with glass but garolite le is the best for non-heated beds if you find a slab flat enough. This looks like acrylic on the knockoff
