Probe XYZ Widget for Tinyg
So, I’ve been working on just kind of a fun little project for no real reason. Just doing some little ‘coins’ and I wanted to be able to engrave images on both sides. I quickly found out that reliably positioning things to do that was not as easy as it sounds. So then I figured what I need is a way to hold my workpiece and to be able to accurately figure out where the center of that piece is.
Once I started playing with the touch plate widget I was hooked on using that to be able to find the zero of the z axis, and decided I needed something just like that for the X and Y.
I had seen some other info on the web on how to do it, so figured it couldn’t be that hard.
So this is what I came up with. Just got done testing it and it seems to find the edges of that little aluminum corner block just fine.
It was really fun working with the Chilipeppr system and I really appreciate how easy it was to fork the touch plate widget, edit it and get another widget working.
