I am trying to trigger few events from a temperature sensor reading. My goal is to issue GCode commands when a thermistor reaches a certain temperature.
I can see the temperature changing with the M105 command but I am having problems with triggering the event.
I have attached the config code I am using:
temperature_control.roomTemp.enable true temperature_control.roomTemp.thermistor_pin 0.23 temperature_control.roomTemp.heater_pin nc temperature_control.roomTemp.thermistor EPCOS100K temperature_control.roomTemp.designator T temperature_control.roomTemp.readings_per_second 10switch.toohot.enable true
switch.toohot.input_on_command G28X0Y0
switch.toohot.input_off_command G0X100Y100temperatureswitch.roomTemp.enable true
temperatureswitch.roomTemp.switch toohot
temperatureswitch.roomTemp.designator T
temperatureswitch.roomTemp.threshold_temp 22.0
temperatureswitch.roomTemp.heatup_poll 2
temperatureswitch.roomTemp.cooldown_poll 5
I can see the temperature going past 22 degrees, but no switch is triggered.
Any ideas or suggestions on why this is not working?
Thank you,
Domenic
