Problems with Atomstack 40
Hello everybody
Im trying to cut a thick carton. Im using 3 or 2 pasess. Sometimes it goes well, but some times it has a shift in the vertical axix os 1 or 2 mm. sometime in the middle of a pass, but mostly when it started the new pass. I checkes the tension of the rail, the screws.
I saw in recent thread that cleaning might help. How do you suggest to oil the rail and guiding wheels?
Any Idea?
Pictures of the problem and your machine would help.
Cleaning is a good idea and should be sufficient. Insure that the guides and wheels are free from debris and the wheel rotates freely.
I would not apply oil as that will only attract more debris.
Hi Don. Many thanks! Ill do it later this evening and hope it helps.
I
