Process: Image converter from .jpg to .stl -> Extrude in Autodesk 123D Design ->
Process: Image converter from .jpg to .stl -> Extrude in Autodesk 123D Design -> Print. - http://pinterest.com/pin/427067977143182114/?s=3&m=google+
Could you list step-by-step how you converted the .jpg to .stl?
Hi @Derek_Cameron ,
Here’s the complete process:
  1. Google “superman logo” ( Now, I am not sure which logo exactly I downloaded from Google),
  2. From @ProfDrafting 's (I learnt a great deal from her) video: https://youtu.be/Jam_cm9J2QA, I lused the image converter site: http://image.online-convert.com -> at Left column “Image Converter” -> Click "Convert to SVG -> Follow the instructions on screen -> Saved the converted .svg image,
  3. Open Autodesk 123D Design -> Import SVG As Sketch -> Click on the 2D image -> Extrude 7.00mm (I like the number 7),
  4. Export STL,
  5. Print.
Awesome, @Ivan_Hoe , I’ll give it a shot
